How do I make certain portions of my video in slow motion? I want to do this for drama effect. Any help will be appreciated. I am using Virtualdub 1.7, to delete scenes, join them together, apply an audio, etc. But I can not find a way to make certain portions of a video in slow motion. Any help will be appreciated.
You can try this, but no guarantees: In VD, save out a section you want to convert to slo-mo and then start a new VD. Open the cut file, then go to 'Video>Frame Rate. In 'Source rate adjustment', change it to a lower number, say 10fps if your video is 29.97fps. Then below that, in 'Frame rate conversion', enter your original framerate, 29.97fps in this case, then save it out with the same codec to a place where you can find it again. I would disable the audio also.
Then in your first VD, under 'File>Append segment', add it back in. You may have to cut and move it to where you want it, and it has to be exactly the same framerate.
The video may be a bit jumpy, so you might want to experiment a little.
Give that a try, if I remembered correctly how to do it.
http://www.youtube.com/watch?v=EzULqlf8598
This app can start anywhere in a video and then switch to slow motion then back to normal speed. Without editing the original. Time-Line playback. The details are in the notes on YouTube.
Free simple tool to export sections of videos?
By Maoukiji in forum Newbie / General discussionsReplies: 6Last Post: 19th Mar 2012, 12:59 -
How to make slow motion???
By X_Splinter in forum EditingReplies: 7Last Post: 8th May 2008, 16:01 -
Slow motion
By Pliny in forum MacReplies: 7Last Post: 7th Aug 2007, 00:02 -
Which casmeras are best for slow motion?
By Deathwish in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 2nd Aug 2007, 23:04 -
Slow Motion
By sbuckmybballs in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 02:16
