I have an audio book on my hard drive and would like to have it on a disk. The file is wav format and will take 16 cd's. Can I put this on dvd or convert it to another format so I do not have to have it on so many of them?
I'd recommend mp3. Many audiobooks come as mp3 files these days. Mp3 files are supported on all portable players. A good, easy-to-use encoder is lamedropXPd, available here:
http://www.rarewares.org/mp3-lamedrop.php
Just start it up and drag your WAV file onto it. Right-click on it to change settings. It will cut your file size by about 90% if you use a 128kbps bit rate, but for voice-only recordings you could probably go lower and save even more. Let your ears be the judge.
And yes, you could put the WAVs on DVD but you'd probably need three of them if you don't convert.
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
bad file names on audio book cd
By NetPhantom in forum AudioReplies: 0Last Post: 27th May 2010, 23:50 -
How to dezone a Mac Power book DVD Player?
By Romain in forum MacReplies: 22Last Post: 17th Jun 2009, 04:33 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 00:00 -
Putting a book on DVD (visually)
By sdsumike619 in forum Authoring (DVD)Replies: 19Last Post: 8th May 2008, 04:46
