I have downloaded and installed the VFapi plugin thing for TMPGEnc and no im not retarded lol, but one thing I want to know is, how can I open the MPG (which is an SVCD format) in TMPGEnc, it sais it is not valid for soem reason...
Did you download and install the Mpeg2 codec (in the Tools Section to the left of this screen)?
I've got the same problem, and I've installed the codec from the download page.
I'm currently running version 12i -
PLEASE POST IN CORRECT FORUM! Moving this one to conversion.
I have also problem opening mpg2 directly from the svcd disc but if you copy the mpg to the hd it often works
or else just use this method for svcd www.vcdhelp.com/mpeg2tovcd.htm because it can open the svcd directly from the disc.
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 08:56 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 09:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
TMPGEnc 4.0 XPress Failed to open mts file
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 11:40 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
