I downloaded the program, is that it what should i do now, I am having a problem converting avi to mpeg, the video course does not open, it says unsupported, help anyone, my head is already blowing up
Download the newest divX codec...and maybe the Krystal Syduio Codec Pack to get some other usefull codecs... then INSTALL... and then every program will find the DivX codec.. even TMPGenc... and you just go ahead and convert.
If the TMPGenc program don't feel like opening the file.. maybe it was'bt fully downloaded? Maybe you're missing a few frames in the end or so, that will mess up the index in the file.
THen... download DivX fix.. that one will rebuild the index so it'll work.. then try again.
Difference between divx and xvid, and the best codec available?
By acommuter in forum Newbie / General discussionsReplies: 33Last Post: 10th Aug 2012, 02:57 -
What is divx and xvid codec?
By Azrail in forum Newbie / General discussionsReplies: 4Last Post: 5th Oct 2010, 22:31 -
DivX and xVid codec
By cheerful in forum Software PlayingReplies: 9Last Post: 10th Jan 2010, 22:55 -
Is there a free DivX codec for Dr.DivX?
By Djard in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 04:33 -
Best free DIVX codec?
By DonGallego28 in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 19:45
