Hi. I have been using this prog fine but now I am getting problems. It seems to be when I join two AVIsd together with VirtualDub Mod and then put them through FAVC. It shows an unnaturally quick time for the conversion and then when it has finished there are only two Vob files in the video folder and it wont play. I am now doing a single AVI and that looks fine. Does FAVC not recognise joined files or something?
It's generally not a good idea to join two AVI files before encoding to MPEG. Can't you just add them both into FAVC instead? Did you try playing them back in a software player after joining? Also check them with Gspot 2.70 to see if there is anything odd with them.
If these were DL'd files, the problem with many AVI files off the net is that they were improperly split and messed up by idiots in every which way possible. But good luck with your files. What it sounds like is corrupted files. -
Thanks for the reply, I did play the joined AVI in a software player and it was fine. Also when I use ConvertXtoDVD it converts fine? So it seems its the FAVC that doesn't like something.
Problem in FAVC 1.07
By kuzutolga in forum Authoring (DVD)Replies: 2Last Post: 22nd Nov 2011, 09:00 -
FAVC problem
By bat5hit in forum Video ConversionReplies: 2Last Post: 10th Nov 2011, 15:50 -
FAVC 1.07 problem
By Rancel in forum Video ConversionReplies: 1Last Post: 7th Oct 2010, 16:30 -
convertion problem- using FAVC
By sumeshkri in forum Video ConversionReplies: 2Last Post: 26th Dec 2008, 17:11 -
FAVC Menu Problem
By marioval in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2008, 05:05
