I have been looking but i cannot find what i need. I have 5 dvds with worship songs that we use at church the problem is i can only use one at a time. Is there a way to put them on my hard drive with the subtitles always on the song. So i can que up songs on more than 1 dvd The dvd are iworship they are vob files on the dvd The progam i use is easyworship
thanks for helping
	You can rip the DVDs in whole to your hard drive with a ripper like DVDFab HD Decrypter or even DVD Decrypter most times. Then you can access them with a program like Power DVD or the freeware VLC Media Player. Both should be able to to play the subs.
 Combining them all together is a bit more complex. You could extract them all to MPEGs with VOB2MBG.
 Or to save quite a bit of space, you could convert them to Xvid or Divx with a program like AutoGK, then combine them all together or just use a player to select them. VLC Media Player works well with those formats also.
 Probably a not of other methods also.
 And welcome to our forums.
	What i need is a video file with the subtitles embedded so they are on all the time. I dont think avi is a problem. Just havent had any luck getting it done thanks
	You could hardcode the subtitles so they are permanently embbeded in the video file. Then when you load them up you don't need to select anything.
 I am no expert on subtitles as I almost never fool around with them. Do a forum search on subtitles and you'll find procedures for how to do this. Note though with any conversion you will have some quality loss.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
