How can I add onto a DVD-RW. Say I have room to put more onto the DVD how can I add onto it without earasing the previous data.
Thanks,
Brian
DVD players do not support multi-session for video.
-If you use the DVD-RW as a data DVD, then adding more data into it is just a matter of copy/paste (using program such as InCD, or whatever comes with your DVD burner).Originally Posted by bshepard13
-If you created this DVD-RW as a DVD-Video, then there is no other way to add more video. Just have to add more video into the existing DVD project to encode them and burn the DVD-RW again. Your old footage will be erased and replaced by the new one. -
Just a correction note for my previous post on adding video to existing video disk: some years back I did try to use a format called DVD-VR (for "DVD-video recording"). This allows for adding more video clips and changing menu on an existing DVD (rewritable). You just open a new DVD-VR project for authoring as usual, and burn the DVD-VR. The DVD-VR can play on stand-alone DVD players. The next time, you can add clips to the same DVD-VR. I used an authoring program called NeoDVD. I have no longer used DVD-VR and do not know how many of the current authoring programs still support it. FYI in case you are interested in this sort of authoring.
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
Add folders to DVD
By marioval in forum Authoring (DVD)Replies: 1Last Post: 2nd Nov 2007, 17:45 -
want to add audio to dvd
By cL0N31 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2007, 02:00 -
Have your NERO & sub it too... add subs to episodic DVD's with DVD-lab
By KneeRow in forum User guidesReplies: 1Last Post: 24th Aug 2007, 01:16 -
Add CSS to DVD's
By Jerk in forum Newbie / General discussionsReplies: 18Last Post: 16th Jul 2007, 04:23
