I want to capture audio+video from IP camera and save it in one MPEG2 file
IP camera produce ...:
- video in M-JPEG format
- audio in G.711 PCM or in G.726 ADPCM formats
I try VLC media player to do it, it works Ok for video capturing,
but I don't know how can I capture audio in that case.
How can I capture both audio and video, transcode and save in single MPEG2 file?
Thank you for help // sorry for poor english, I'm doing my best =)
Sorry for my awfull ENGLISH =|
guns1inger, I want to do it in real time, I cannot save audio and video separately and multiplex these later.
Baldrick, no, I cannot. But it is obviously, because I open M-JPEG stream only, it does not include audio.
I've just found out that Axis 207 IP camera may produce MPEG4.
Can anybody say me something about it? Does it include audio?Sorry for my awfull ENGLISH =| -
mpeg4 is just a video compression format. MP4 is a container that may contain video and audio.
If you have set everything up correctly through the AMC control panel, you should be able to stream mpeg4 from rtsp://<ip>/mpeg4/media.amp (insert your IP address, naturally).
Also, the manual seems to indicate you cannot set the volume levels through the AMC control panel, but only through the web page for the camera.Read my blog here.
Capture video from CCD camera through USB?
By vcao102 in forum Capturing and VCRReplies: 5Last Post: 7th Feb 2012, 20:07 -
Capture video from DV-camera and audio from soundcard
By NiQ in forum Capturing and VCRReplies: 1Last Post: 25th Mar 2010, 11:57 -
capture screen with video camera issue
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2009, 09:03 -
Capture video signal from a camera to a laptop
By Cazz in forum Capturing and VCRReplies: 4Last Post: 15th Feb 2009, 15:17 -
Capture from PC to Video Camera
By gamerscircle in forum Newbie / General discussionsReplies: 14Last Post: 4th Jan 2009, 12:21
