I have a P3 600Mhz 256 MB, computer. Eveytime I try to watch a DVD or Xvid video file on full screen the
picture freezes every few seconds, because the CPU is at 100%. It's impossible to watch. Which video playing software has the lowest CPU ussage?
I've tried Windows Media Player, KMPlayer and VLC, all with the same result.
P.S
Please don't reply with an advice to buy a new computer, unless you are willing to purchase one for me!!
Thanks in advance.
Results 1 to 9 of 9
1.change screen resolution to 640x480 16 bit
2.disable all autoloading programs which are not needed
3.divx-disable post processing -
Your current PC should be fast enough for DVD playback, at least in a window anyway. Full screen would be questionable without a video card with hardware mpeg2 support.
You also list two different amounts of RAM. Your first post lists 256MB and your computer specs list 512MB. If you do only have 256MB, then that is also likely contributing to your issue. XP needs a minimum of 512MB for proper operation without hitting the swapfile continously.
Use task manager to monitor your cpu usage and watch your HDD LED while playing a DVD to see if there is excessive HDD usage.Google is your Friend -
you guys hawe wrong. If you hawe 16-bit on the system it becomes lower colors and that gona make the video go slower becose it nead to change the grafic in the movie. And the movie ar build to hawe one performance all the time
Hmmm, let's see if the O.P. really will come back for watching this thread again, 5.5 years later
Hahahaha. If he still has that pentium3, 5 years later, we should all pitch in and buy him a pentium4, so he can watch all of his out dated divx encodes.
What do i need if CPU usage goes 100% when video editing?
By NaHLiJ in forum Newbie / General discussionsReplies: 19Last Post: 28th Dec 2013, 20:13 -
Low cpu usage decoder+render for netbook...
By elmuz in forum Newbie / General discussionsReplies: 5Last Post: 30th Jun 2011, 06:34 -
Some .vobs loaded in Vegas Video cause 50%+ CPU usage - why?
By kmxe in forum EditingReplies: 10Last Post: 23rd Apr 2009, 00:04 -
Extremely low burn speeds, High CPU usage
By BetaMaster in forum Authoring (DVD)Replies: 13Last Post: 20th Nov 2008, 13:23 -
Vegas rendering - Low cpu usage on 8-core
By lapoune in forum Video ConversionReplies: 5Last Post: 2nd Jun 2008, 11:07
