i have recently changed to windows vista premium and am currently adding all my old programs to it .
i have installed svcd2dvd v2.5.3600 fine and it works ok and creates dvds fine but whenever i open a folder that contains an avi that has been converted to a s2d file i get the following error :
windows host program (rundll32) has encountered a problem and needs to close
after that it checks for solutions , but if the folder with the s2d file in is open that message will continuosly pop up.
this means that i cannot batch create files for creation later
anybody have any idea what is a matter ?
i am running vista premium
core2quad 2.6
4gb ram
500gb hdd
i dont believe that this setup should have any trouble at all
the prog was not installed in the programs folder either
any help would be appreciated
thanks
rich
i suspect vista is trying to make a thumbnail preview and failing.... Can you play the mpeg in WMP?
yes i do have nero installed , vista didnt like nero showtime but i disabled that and solved that problem . as for playing the mpeg file i havemt tried . to start with it didnt like the vob files that were created but i associated them with wmp and it was sorted . i think it is probably like you say because i do get little thumbnails of the avi's in the folders . how do i disable this ??
I had the same problem. It is cause by the search engine from the Nero. You have to uninstall that part of nero.
Or google on the error and see what you type in.
help with icons on vista home premium
By wingnut2003 in forum ComputerReplies: 11Last Post: 8th Jan 2010, 07:21 -
No audio with pinnacle studio 12.1 on vista 32 premium?
By yoda313 in forum EditingReplies: 0Last Post: 26th Oct 2008, 15:05 -
VFAPI problem on Windows Vista (Home Premium)
By foochuck in forum Video ConversionReplies: 1Last Post: 3rd Nov 2007, 18:10 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 12:01 -
DVX100B to Vista Home Premium - Nightmare!
By Tobuscus in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 13:34
