Here is my scenerio. Say I have an .TIB (True Image Backup file) on an external drive. The pc I want to put it on has a brand new just out of box hard drive installed how would I go about putting said .TIB file on to this new drive, so that it's just like my old drive before it died? Don't be afraid to add step by step process....haha...thanks
What We Do In Life, Echoes In Eternity....
Is the original installation cd also a bootable recovery cd?
What We Do In Life, Echoes In Eternity.... -
I doubt it - you usually have to create the bootable CD. I did...Originally Posted by Denvers DawgsThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
The manual is here : http://download.acronis.com/pdf/TrueImage11_ug.en.pdf
The section you want is 6.1Read my blog here.
The original CD is bootable on version 9 at least. Thats the only one I've got that I actually ordered on CD. Just slap it in the drive and find out. No harm in trying.
Ok so I looked over that manual and under CH 11 it says if you purchased a boxed product then I already have a bootable cd, because the install cd itself is bootable..Thanks guys for the help
Acronis True Image 2010 or NeroBackItUp
By kenmo in forum ComputerReplies: 13Last Post: 18th Nov 2009, 23:55 -
Acronis restore question...
By Captain Satellite in forum ComputerReplies: 6Last Post: 26th Sep 2009, 15:22 -
Windows7 & True Image
By beam_brandon in forum ComputerReplies: 1Last Post: 23rd Sep 2009, 05:08 -
Quick Question on Acronis Home
By ranchhand in forum ComputerReplies: 0Last Post: 28th Nov 2007, 10:19 -
How to backup sytem/hhd using Acronis True Image 10?
By evol ecallaw in forum ComputerReplies: 5Last Post: 1st Jul 2007, 02:03
