When I use Pinnacle Studio 10 to encode a video, the final video shows horizontal lines. Is this interlacing or scan lines? I wish to get rid of them. These appear encoding to an MPG II and a DivX file.
Any information is appreciated. Thanks in advance!![]()
GrunbergGuest
I would use a mpeg2/dvd editor instead and you don't have recompress it all. You can use tmpgenc dvd author to import dvds directly and do basic editing(cut/join), reauthor and make a new dvd. Or if you want more advanced editing(transitions) use mpeg video wizard.
Mpeg2 and windows movie maker is not worth it because it's too buggy. -
GrunbergGuest
Awesome! Thanks for the response. Now - as far as the horizontal lines I'm seeing throughout the screen when Pinnacle converts the video - is that evidence of scanlines or de/interlacing? I'm confused...
And how would I go about normalizing the audio in all my clips?
Vertical lines with Pinnacle Studio 14/510 USB card
By karebo in forum Capturing and VCRReplies: 0Last Post: 11th Dec 2011, 16:54 -
horizontal lines in x264 encoded dvd using MeGUI
By codemaster in forum DVD RippingReplies: 5Last Post: 9th Dec 2010, 07:48 -
Horizontal black lines in exported HD video
By progressive_pete in forum Video ConversionReplies: 5Last Post: 25th Jan 2010, 08:36 -
Horizontal Lines making video unbearable
By Fatalize in forum Capturing and VCRReplies: 5Last Post: 20th Sep 2007, 13:27 -
Horizontal lines on video playback with vista
By richard.fisher in forum Software PlayingReplies: 7Last Post: 4th Jun 2007, 09:48
