I tried searching and found a reference to yamb but wan't able to import the files
What I would like to do is edit mpeg4 files that I download as wmv ideally with out recompressing them
Any suggestions would be really appreciated
Hello mrready,
this seems to be a little confused. mpeg4 is a class of compression, as implemented in the codecs for DivX, XVid and H.264 (among others). MP4 is a container format like AVI, that is, a kind of file format. You can have an AVI with mpeg4 compressed data inside, or an MP4 with mpeg4 compressed data, but these containers could contain also differently compressed data. WMV is a specialty of microsoft and describes a compression and a file format.
If you want to cut AVI, use VirtualDub (frame-accurate without recompressing with V.1.7 or later, use SmartRendering) or Avidemux.
If you want to cut MP4, use MP4Box (can cut only on keyframes)
If you want to cut WMV, use AsfBin (frame-accurate without recompressing with V.1.5 or later, use -rkf option)
A simple GUI (graphical user interface) for these programs is Cut Assistant. Another GUI (only for AsfBin) would be Movica.
HTH -
for editing without re-compressing avi files Virtualdub will be the best. For wmv files Movica, though still in beta stage, is the best so far, and it is free, just like VirtualDub
Problem converting videos from MPeg4 to wmv
By TomH309 in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2012, 09:30 -
Which software to edit dreambox mpeg4 ts?
By manutd in forum EditingReplies: 11Last Post: 3rd Jan 2012, 08:00 -
Easy edit DVD video cutting out unwanted stuff without recompressing
By deadp0et in forum EditingReplies: 6Last Post: 7th Feb 2011, 07:49 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 07:01 -
What is the best way to edit MPEG4 files
By Paul W in forum Newbie / General discussionsReplies: 8Last Post: 1st Apr 2008, 11:32
