Does the GL2 auto-detect a phantom mic and provide 48V phantom power? I'm using a top-mounted XLR attachment - the level for the phantom lav I attached is low. Does it matter if I use one phantom and one powered mic (left and right XLR ports)? Thank you!
Did you use Beachtek DXA-4P or DXA-6VU? GL2 doesn't have any XLR connection or phantom power. You'll need a Beachtek DXA-4P or DXA-6VU if you want to use an XLR plug. The VU has 48v phantom power.Originally Posted by kippard
vcdlover
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 21:11 -
LG HT 305SU (MIC IN / MIC OUT Problem)
By iamjamal in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2011, 17:38 -
Canon XM2/GL2: Wireless Lavalier Mic Question
By Xenon77 in forum Newbie / General discussionsReplies: 9Last Post: 29th May 2009, 21:25 -
Getting a film look with a Canon GL2
By pbear23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 2nd Oct 2008, 19:17 -
Canon GL2 16:9
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 6th Oct 2007, 00:13
