I'm trying to use Subtitle Creator to convert a subtitle file from SUB to SUP so I can use it w/ SVCD2DVD. However when I try to load the SUB file in subtitle creator it keeps saying "Error reading subtitle number 1. (Index was outside the bounds of the array)"
Does this indicate a problem with the SUB file or is there anything I can do to properly convert this file? I searched google and couldn't find any results. I posted this here since Subtitle Creator is essentially needed to do subtitles in SVCD2DVD.
Please help! :)
I'm trying SUBtoSUP (http://www.softpedia.com/get/Multimedia/Video/Other-VIDEO-Tools/SubToSup.shtml)
I'll let you know how that works.... -
That worked w/ SVCD2DVD. I think the problem was that the original SUB file had multiple streams - otherwise I dunno.
SVCD2DVD did show wierd percentages when processing the subtitle file (went up to 500% then back down a bit) but the DVD came out fine.
Hope this helps someone else maybe.
Cheers! -
Thanks for the info acid_burn.
Subtitle Creator never worked for me also - only good for converting SRT to Sup.
Fl
Unable to find "Play next clip" when authoring DVD
By zonag5 in forum Authoring (DVD)Replies: 4Last Post: 16th Oct 2010, 01:50 -
TSPE error in version 0.76 - Index was outside the bounds of the array.
By bildry in forum EditingReplies: 0Last Post: 9th Apr 2010, 14:56 -
VOB2MPG Index out of bounds error when trying to convert some DVDs
By secretsubscriber in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 1st Mar 2010, 09:35 -
Camtasia Error : "Unable to write AVI file frame"
By ShinuMirai in forum Newbie / General discussionsReplies: 8Last Post: 11th Oct 2009, 15:19 -
BD INfo Error : Index was outside the bounds of the array
By ripper1234 in forum Blu-ray RippingReplies: 0Last Post: 28th Jun 2009, 08:29
