What's the best authoring program to convert h264 to DVD without losing as much quality?
I only have DVD-5's, I know if I had DVD-9's I would be in better shape, but they're too expensive.
I have tried Nero 8 to author AVC h.264 (AVCHD) files to standard def files in a DVD-5. The quality of the DVD is very good, fairly close to AVCHD quality (on an upconverted DVD player), and far better than one that we can author with videos from a miniDV cam (SD).Originally Posted by tj1182
DVD-9 would not give us better video quality, just more disk space for more video.
I have not tried other programs to comment on which is the best. -
I've tried using Nero 8, and it always surpasses the 4.4 GB limit for a 42min file. I don't want to delete any time off the video.Originally Posted by Ollie6431
I experienced the same thing when using Nero 8, the encoding process somehow increases each video clip's size up about 50% more. Throwing in the menu files and one can barely keep 20 - 30 mins of footage. If you need to keep the full 42 mins of video on DVD using Nero 8, probably the only way is to use DVD-DL. Other authoring sofwares may keep the 42 mins on a DVD. I do not know about those to comment on.Originally Posted by tj1182
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 15:13 -
Converting streaming MPEG-2 to H264
By tripflex in forum Video Streaming DownloadingReplies: 1Last Post: 12th Apr 2010, 16:49 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 10th Apr 2009, 00:56 -
problems with an .h264 mvk converting to DVD with .srt subs
By jbeaman in forum ffmpegX general discussionReplies: 1Last Post: 2nd Aug 2008, 10:56 -
MacOS 10.5 > mkvtoolnix > Converting MKV (H264/AVC+AC3) to DVD
By Savant2k6 in forum MacReplies: 0Last Post: 16th May 2008, 16:58
