I have a Panasonic AG-HVx200 that came with an Azden WMS-PRO wireless lav. I can't figure out how to use the wireless lav witht he camera. Are these two compatible? Do I need a converter? If not....what kind of wireless mic can I use with the AG-HVx200? THANKS!
I think your problem may be that the mic inputs are xlr & the Azden has a mini connection. If that is the case then yes you will need an adapter. Any good professional Audio/Video supplier should be able to supply you with the right adapter. B & H is one that comes to mind. I've dealt with them in the past & they seem to have just about everything, or possibly the dealer you got the camera from, but I'm kinda surprised that they would sell you a mic system that is not compatible with your camera. Actually, the mic is compatible, just the connectors aren't. I would have thought that your supplier would have included that with the setup when you bought it.
A Panasonic AG-HVx200 is a $6000 (plus P2 cards) DVCProHD pro camcorder. The Azden WMS-PRO $100 wireless lav is something you would buy to tape your sisters wedding with a Hi8.
You would need to build or buy a Hi Z mini mic to XLR adapter and switch the HVX input from balanced low to Hi Z.
Explain what you are trying to do. Or go to any GuitarCenter or Radio Shack for a consumer Low Z 600 ohm XLR mic solution.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Similar to this but with mono mini jack on the other end. Switch mic input to high impedance.
Please help... Importing problems with Studio 14HD and my Panasonic HVX200
By tvcamgrl in forum EditingReplies: 2Last Post: 10th Jan 2012, 15:58 -
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 19:23 -
WMS Stream in WMP / Vlc
By river3 in forum Video Streaming DownloadingReplies: 0Last Post: 15th Jun 2010, 04:18 -
Beeping on audio on Panasonic HVX200
By spandau in forum Newbie / General discussionsReplies: 0Last Post: 18th Dec 2007, 23:29 -
Will HVX200 play MiniDV tapes?
By oliverw in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 29th Jun 2007, 22:54
