sorry to be dumb but how do i convert svcd into vcd it sounds mad but some of my friends cant play svcds cant do it with TMPGEnc any ideas or have i got the settings wrong ?
thanx in advance for any help
I just did it with TMPGenc 12h, what happened for you?
/Lars
Thanx/
Lars -
i loaded it into the main screen but it said file unsurported ? ive burnt it with nero(5524) and it plays on my pc dvd and outputs to tv ive tried tools multiplex but i end up with a useless file thanx in advance for any help
How did you encode the mpeg-2 file in the first place? With TMPGenc?
Maybe you should try Cinema Craft Encoder?
Thanx/
Lars -
I always (and I do mean always) am unable to open MPEG-2 files of any kind in TMPGEnc. My solution is to create a project file of the MPEG-2 using DVD2AVI. Then you can open it up in TMPGEnc again.
I have to do this with every Radeon capture I do, it's a pain (plus you have to work around an audio offset, another issue entirely...) but it WORKS.
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 02:12 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
