Ive got windows media center Vista , when browsing the videos, music, tv guide with the remote it just goes to a different section, sometimes closes the media center all together.
Little letters appear when click left and right. if going up and down in the menu it will select somthing like settings.
if in the guide looking at BBC it will jump to E4 which is another channel 10 channels down.
What could be wrong its not a virus as its only been connected for updates but it starting to feel I am not in control of the system. Any ideas?
Is someone "pulling your plonker" with another remote control??
which remote control??Corned beef is now made to a higher standard than at any time in history.
Have you considered the possibility that Vista is just a piece of ____ ? You really should. I'll spare you my long story, but one of my friends tried to add some memory to a laptop running Vista. He bought the correct memory and put it in correctly, yet Vista refused to boot and it required a complete reinstall from DVD of Vista to make his laptop work again. Lovely OS, that Vista - not.
I have Vista on three machines presently. No problems. I just updated my new Vista laptop to 2GB of RAM, works great.
But I don't use Media Center and I don't have a remote for it. I suspect you have a problem with your remote, or the IR receiver, or something in the IR program that's acting up. Try this: Move right up to the IR sensor and try again. If that helps, it might be interference or a weak IR signal.
I would also look into reinstalling the IR program. Does your IR receiver plug into the USB port? If so, try a different port, and try unplugging all other USB devices for a test. It could be the USB ports messing up.
BTW, is your Media Center a prebuilt computer? If so, what brand? Any other specs, such as the Media Center card? -
can you get a remote that broadcast RF. Then have a RF receiver by the PC that translates into IR and sends the IR signal out?
I've got Vista running on my laptop - no problems, but I don't know what amazing things I was getting with it.
I installed Ubuntu+Beryl on an old machine - wow, from eye candy POV, Vista looks silly trying to pump their Aero.
Search YouTube for Ubuntu+Beryl to see a demo. -
There's nothing wrong with VISTA other than the usual idiosyncracies associated with a new platform. Dos 2.0, Dos 3.3, Dos 4.0, Dos 5.1, Dos 6.0, Concurrent Dos, Windows 3.1, Geoworks, Windows 95, Windows 98, Windows NT, OS/2, Windows XP all had their issues.
But this problem doesn't sound like an OS problem.
Does MC work from the keyboard?
MarkMatters of great concern should be taken lightly.
Matters of small concern should be taken seriously.
DVD Burner life
By hibbs in forum DVD & Blu-ray WritersReplies: 7Last Post: 23rd Sep 2009, 16:23 -
Good Battery Life
By Arlo in forum Portable VideoReplies: 2Last Post: 22nd Apr 2009, 14:52 -
Day In the Life of an IT Guy
By Soopafresh in forum Off topicReplies: 5Last Post: 1st Sep 2008, 05:59 -
The secret life of the penguins
By Midzuki in forum Off topicReplies: 1Last Post: 29th Jul 2008, 08:02 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 13:01
