Hi folks,
I have a music DVD that a buddy recorded from TV many years ago and the DVD is essentially one long chapter. I would like to import the DVD into TMPGENC DVD Author, add song titles/chapters and then burn a new DVD. Will I lose any video quality by ripping the DVD with DVDFab Platinum, importing the files into DVD Author, outputting new VOBs and then burning a new copy?
Other than creating DVD-Video compliant files, I'm not too clear on what else happens when the "Output" option is selected
Thanks for the help!
Roberta
Nope.Originally Posted by robertazimmerman
/Mats -
You should be able to use the Source Wizard Button in TMPG DVD Author and import the DVD directly. My version doesn't convert MP2 audio to AC3 without some audio quality loss, so I seldom use that feature.
You can skip the step of ripping the DVD with DVDFab Platinum. TMPGENC DVD Author has an option to "Add DVD Video" on the "Source Setup" screen. You can choose to work directly from your DVD or copy the files to your hard drive from there.
Problem burning a project on to a DVD from TMPGEnc Author 3
By vhsal in forum Authoring (DVD)Replies: 5Last Post: 21st May 2011, 19:25 -
GUI DVD Author Project default setting
By Genevieve in forum Authoring (DVD)Replies: 4Last Post: 29th Apr 2009, 02:10 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 20:53 -
Divx Author Project File to DVD?
By grandsire02 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 22:32 -
Help to finish a basic DVD project with menu, chapters and videos?
By mikeli in forum Authoring (DVD)Replies: 4Last Post: 29th May 2007, 12:11
