I have suddenly lost the sound when making a dvd from a recorded tv program. I'm pretty sure its not the burning software as I have tried burning with Easy media creator 10 and ConvertXtoDvd. The picture quality is exellent but no sound.
If I play the files on computer before burning everything appears ok. This has suddenly happened and I've burnt dozens of dvd before with no problem. has anybody any ideas as to what might be causing this problem
many thanks for any help
If the file(s) play back normally on the recorder, then the files are likely OK. There is a two step process on your PC, you aren't just "burning" discs. First you are converting the files from the format used on your recorder to mpeg2 dvd compliant files. Then, they are burned onto disc. The problem is likely in the conversion process. To verify, just try playing the converted files before they are burned onto DVD. Most conversion software will allow you to create iso files instead of burning. You can then mount/play the iso files from your HDD.
Google is your Friend
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
Lost Audio i think
By oz_surfer in forum AudioReplies: 2Last Post: 14th Jun 2010, 10:04 -
Convert .wtv to .dvr-ms and lost audio?
By greyfalcon in forum DVB / IPTVReplies: 0Last Post: 24th Mar 2010, 03:53 -
lost audio after effects vers 6
By santolina in forum EditingReplies: 2Last Post: 26th Jul 2009, 07:05 -
Once Again, VirtualDubMod Has Lost My Audio Decompressor
By Mitchum22 in forum AudioReplies: 2Last Post: 29th Jan 2009, 06:55
