Hello, i would like to ask whether this since-always problem i got is common or not and how should i fix it.
Most of the mpg/avi videos i download and then try to convert and burn into DVD are ridiculous in terms that audio and video do not match. My pc is not very fast but i can't really think that this is the problem since i can successfully do other multimedia jobs. I have used a lot of different programs and methods to overcome this problem but they are either useless or they take such a long time that finally doesn't worth it.
Any suggestions?
What tools are you using? ConvertXtoDVD is best for downloaded material.
Well depends on the source... Most often i use WinAVI Video Converter for the conversions and then either dvd shrink to compress 'n burn or dvd-lab pro to make some further stuff to compile. i will try your suggestion too though. In case the source video has the problem, do you know any fixing solutions?
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 04:14 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23
But
