Hi,
I wonder if I extract the contents from a MKV with MKVExtractGUI and put those back into an OGM, should the file sizes be the same? The OGM files seem to be a bit bigger in size by some megabytes. Maybe just how each container interprets it or something? Not much of a problem, but just wondering. I haven't done any conversions, I just took exactly what I extracted from the MKV and muxed them in an OGM. I'm using VirtualDubMod to mux them. Or is this normal?
Ah ok, thought so. I was also wondering if there is a better OGM muxer to use than VirtualDubMod. I am looking for something that can name the audio streams mostly instead of showing, "unknown" or "undetermined."
I believe VirtualDubMod's OGM handling is quite outdated. I don't know about naming streams but you might try AviDemux.
Actually, I think it works okay enough for OGMs... I don't think any specifics for OGM have been updated since VDubMod was last updated, but I could be wrong.
As for naming streams... I don't know, either. :/If cameras add ten pounds, why would people want to eat them?
Converting OGM and MKV
By Jeikobu in forum MacReplies: 9Last Post: 3rd Jun 2011, 01:30 -
Whats the best sizes for ripping blu-ray to mkv
By adamf154 in forum Blu-ray RippingReplies: 4Last Post: 11th Jul 2010, 21:06 -
re encoding MKV files with subs to smaller file sizes with min qual. loss
By malakov08 in forum MacReplies: 1Last Post: 4th Apr 2009, 03:06 -
Converting OGM/MKV to AVI
By DarkManX4lf in forum DVD RippingReplies: 11Last Post: 30th Dec 2007, 16:16 -
MKV & OGM to RM under 100mb
By bloodyred in forum Video ConversionReplies: 2Last Post: 10th Sep 2007, 18:06
