I am using DVDshrink to copy dvds. am using Vista premium. I used it once before to copy a dvd it went thru fine.
Now I went to copy another dvd and it anyalys's fine but when does it's encoding thing. it will reach about 33% and it will freeze. I've tried uninstalling, reinstalling did system checks, and still nothing.
Please!, if anyone one can help! I am at my wits end.![]()
Results 1 to 9 of 9
What flick?
And try rip with DVDFab HD Decrypter> Shrink (if compression is needed)> IMGBurn" Who needs Google, my wife knows everything" -
I tried two diferent movies, superbad and 3:10 to yuma. which I was trying to copy from copies. But the one that worked was a copy of Charloetts web and that one worked fine. Now both that I had tried stop at 33%.
Also, some drives work better than others with marginal or protected discs. My LG GSA-H55N 1.05 seldom fails to read a disc, but my Lite-On LH20A1P KLON aborts with "cyclic redundancy check" (CRC) errors fairly often. Sometimes cleaning the disc helps. Sometimes just trying it again, repeating several times, will eventually get it to read. However, please note that trying to read bad discs repeatedly that return CRC errors can put your drive into PIO mode permanently, requiring extraordinary measures to return it to normal DMA mode operation!
http://winhlp.com/node/10
Are there any other programs like dvd shrink that do the samething that is compatibile with vista?
My problems is not with just 3:10 it's with any movie I try. Is there any certain setting in either dvd shrink or vista that I can change.
The drive could be bad. To find out, substitute a different one. You should have a backup handy anyway.
Better yet, install two, preferably different brands, then you'll always have a backup handy. I suggest that one of them should be a Lite-On or Benq so you can do quality scans of your burns.
Are you using Shrink for rip>copy>burn?...
Shrink is outdated. Though still a very good program, what you need is a new ripper for newer movies....
DVDFab HD Decrypter or better yet Fab Platinum..others will suggest their preferences...
As stated above try, DVDFab HD Decrypter>shrink >IMGBurn
You can skip Shrink all together if no compression is needed or you burn to DL media.." Who needs Google, my wife knows everything"
Problem with DVDShrink
By abba1961 in forum DVD RippingReplies: 3Last Post: 22nd Mar 2010, 01:52 -
Vista problem with SVC2DVD
By PerryM in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 27th Aug 2009, 13:34 -
"DVDshrink - Vista where is Application Data Analysis files located?
By mn072065 in forum DVD RippingReplies: 2Last Post: 24th Feb 2008, 17:43 -
Problem with dvdshrink
By malleus in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2007, 21:03 -
Windows Vista Problem :(
By 1magus in forum DVD RippingReplies: 5Last Post: 24th Jul 2007, 22:08
