Hi![]()
My original video is 16:9. After I used FAVC105 to convert it to DVD, the A/R was changed to 4:3.
How can I keep the original aspect ratio with FAVC105?
Results 1 to 22 of 22
FAVC105's DVD Option tab does not have any choice for aspect ratio. I think I will have to get 1.06 version.
Hi:
My AVI file was read by DivXToDVD as 16:9 when it was converted to DVD. Then my DivXToDVD-converted DVD played in both stand-alone and DVD drives, displaying 16:9 screen with top & bottom black bars. VideoRedo read the vob files and also showed 16:9 aspect ratio.
These videos (AVI & VOB) do not have subtitles.
Now I have the subtitles and want to add them to my video. Then I saw the FAVC's subtitle function and wanted to try it out. (see my post in the subtitle thread)
After Baldrick's kind assistance
, I was able to make the subtitle show in VideoLan but then the picture was changed to full screen, instead of the original widescreen/letterbox.
At first, I thought I would have to set the aspect ratio in VideoLan to 16:9 for proper displaying of my video. But I saw VideoLan's autodetect was checked. So I suspected that the video's aspect ratio was changed to 4:3 and VideoLan's autodetect picked it up as such.
So, I used VideoRedo to open this FAVC-converted DVD. Sure enough, the stream information given by VideoRedo showed 4:3 aspect ratio. -
What are the dimensions (height/width) of your original avi file?
It would be nice to have an option or an override in the GUI.
There are still people who like to encode widescreen material as letterboxed 4:3 (sad, but true), and others who would prefer to encode 1.66:1 and even 1.37 or 1.33 material as 16:9 with pillarboxing.Read my blog here.
Hi, I thought the frame size has nothing to do with a video's aspect ratio. For example, if the aspect ratio of a video is 16:9, it will be displayed 16:9 whether the frame size is 640 x 272 or 704 x 416 or 720 x 480 or some other "crazy" frame size. Whether or not the frame will fit a monitor screen is a different story, but whatever is displayed on the screen will remain its original aspect ratio; i.e. the faces will not be elongated and spreaded.
No? -
That can be the case - but most of the time in avi files the frame size ratio is the same as the display aspect ratio.Originally Posted by moviebuff2
FAVC is set to encode 16:9 when this is little or no pillarboxing (1.74 : 1 AR). Your video is 1.69 : 1, which is below the threshold for FAVC, hence it is encoded as 4:3. Unless Mr_Odwin choses to alter the way FAC functions, you may have to use ConvertXtoDVD or DVD Flick for this file, or look at doing to avisynth work beforehand to trick FAVC.
Read my blog here.
Hi guns1inger:
Thanks for the advice.
I used VirtualDubMod, added top/bottom black bars, added sub to the bottom black bar (much easier to read for old man like me, LOL), 10% sharpen, multi-pass 2 times, to make an AVI. After that, DivXToDVD converted my hard-code sub AVI to DVD (frame size: 720 x 480, including the black bars).
The hard-coded sub AVI is for me to keep. The 720 x 480 DVD is for my friends who do not have DivX player.
FAVC will be used to convert other formats such MKV to DVD. It's pretty slow (6 hours for 90 minutes of video). -
guns1inger wrote:
Oops, sorry Mr_Odwin. Sorry I missed this part. Thank you for your wonderful program. I really mean it.Unless Mr_Odwin choses to alter the way FAC functions,[...]
Hi guns1inger:
I'm using the laptop I inherited from my brother. It has WinXP. The 6-hr conversion was done with this laptop. I agree with you that quality comes with a price. I chose the best possible quality setting. So, I'm not complaining. I just want to reserve FAVC for video files that other softwares cannot handle, for example my last MKV file could not be read or converted by DivXToDVD, AVI2DVD and VideoLan. FAVC came to the rescue.
FYI, I just used FAVC to convert an 86-minute AVI (608 x 272, aspect ratio 2.235) to DVD. FAVC just automatically recognized it as 720 x 480 resolution and showed this info in the source file information. And the time it indicated would take to finish the 1st pass was +5 hours. I will let you know how this turns out. I still have approximately 9 hours left. -
Read my blog here.
REALLY STRANGE RARE THING: MPG video CHANGED after file transfer or copy
By xboxsold in forum Newbie / General discussionsReplies: 21Last Post: 1st Feb 2011, 10:28 -
Error with FAVC Video Conversion
By IllusionOfLife in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2009, 18:38 -
FAVC video artifacts
By midders in forum Video ConversionReplies: 5Last Post: 24th Sep 2008, 02:33 -
help using FAVC
By eao1 in forum Newbie / General discussionsReplies: 3Last Post: 1st Sep 2008, 19:41 -
Help Please ! Changed video card and now, can't play HD Content
By rfengineer in forum ComputerReplies: 4Last Post: 2nd Sep 2007, 22:05
