Results 1 to 17 of 17
I added three AVI files again in order to transfer them to DVD files. I checked the files in powerDVD, winDVD and VLC-player without success, the sound is gone. I checked the file in Gspot, but I couldn’t see any errors, see attach image.
http://img210.imageshack.us/my.php?image=gspotfavcbc2.png
The sound is included if I add the files into convertxtodvd.
Mark -
This is very odd. What type of audio do the avi files have and do you have the correct directshow decoder installed for the audio?
I have no idea if I have the correct directshow decoder is installed. I downloaded the latest FAVC and use its accessories, of which HCenc is one.Originally Posted by Mr_Odwin
The audio of the AVI files are 2.0 AC3
The strangest thing is that the movie work perfectly when using convertxtodvd, except that the movie is somewhat jagged, but I think it is from converting from NTSC to PAL.
Mark -
Exactly, I don’t know why I ticked off that I wanted NTSC to PAL converting, as my equipment can play NTSC.Originally Posted by guns1inger
But why is there no sound when transferring 3 AVI files to DVD in FAVC, when it is sound while doing the same thing in convertxtodvd?
Mark -
In the audio options tab of FAVC make sure that "retain if present" is selected for AC3 Audio. Try an encode again.
'Retain if present' is selected in the audio option.Originally Posted by Mr_Odwin
Mark -
Make sure you have the AC3 ACM Decompressor installed. Having this installed might fix things and surely will not hurt things even if this turns out not to be the issue.
I'd also make sure that you have the AC3 Filter installed as well.
Just install the programs and then run FAVC as usual.Originally Posted by Belfour
Please, could you tell me a reason why the sound works after I’ve converted the files in convertxtodvd, because it’s beyond my knowledge?Originally Posted by FulciLives
Mark -
As far as I know convertxtodvd uses some sort of ffmpeg process in the background (that may not be true - but I think I read it somewhere) whereas FAVC uses codecs on your computer (directshow for audio processing).
Is there a faster way of converting MKV to mpeg2 for DVD than FAVC?
By Onceler2 in forum Video ConversionReplies: 1Last Post: 31st Jul 2011, 17:55 -
problems with favc and the muxing of the dvd
By kronick in forum Authoring (DVD)Replies: 10Last Post: 7th Sep 2009, 18:05 -
Making a DVD menu from .VOB files created by FAVC?
By whatever911 in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2009, 04:13 -
Transferring MPEG-2 file from the Favc conersion to DVD using Nero 8 (Vis 5
By pay1000 in forum Video ConversionReplies: 5Last Post: 29th Jun 2008, 22:24 -
AVI to DVD w/ FAVC, Failure to Read
By Bullneck in forum Video ConversionReplies: 3Last Post: 2nd Apr 2008, 19:09
