The navigation command's editor in DVDAuthorGUI allows you to chose whether to return to the menu (call menu) or restart the title or exit the dvd at the end of a title. This is okay if you have one menu screen and want everything to return to the main menu afterwards. What if you want to have another menu such as one for extras? Is there a way in the nav commands to "call menu" back to this secondary menu rather than going back to the main menu at the end of a title?
You can do that with DVDAuthorGUI by enabling the 'Jump Table' Feature under 'tools'.
Thanks!
Off topic, but are there any plans to allow DVDAuthor and/or any of its GUI's to author multiple titlesets as different VTS files if you have different aspect ratios? -
@ecc:
Try GUI for DVDAuthor. The tools section of this site (at the left of your screen) reports that it can do multiple title sets.
Note: I haven't tried GUI for DVDAuthor myself, just going by what the tools section says about it.
CogoSWSDSOld ICBM Coordinates: 39 45' 0.0224" N 89 43' 1.7548" W. New coordinates: 39 47' 48.0" N 89 38' 35.7548" W. -
I'll take a look at it but I prefer DVDAuthorGUI's interface and menu editor.
dvdauthorgui menu question/problem
By tacitus in forum Authoring (DVD)Replies: 7Last Post: 11th Oct 2011, 22:53 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 12:52 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 08:04 -
DVDAuthorGUI: Menu problem
By videohalp in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2008, 22:11 -
call menu 2 after film in DVDAuthorGUI
By awesomer in forum Authoring (DVD)Replies: 8Last Post: 5th Mar 2008, 18:55
