hey. i know this is very newbie-ish but please bear with me. on my computer i have an ATI Radeon 64 capture card which consists of ONE composite in, ONE composite out, and ONE S-Video out. my camera consists of one A/V out, one S-Video out, and one wierd thing that is really small. well i am able to connect my s-video out to an adapter that changes it to composite and i plug it into the composite in my computer, but all i can get is video, is it possible for me to get audio?
thanks
i dont think i have a sound card..... i hear soudn and everything but i dont think i have a designated sound card... what does the plug look like?
Assuming you have sounds beyond basic beeps:
Your speakers are plugged into a hole using a plug about 1/8" in diameter. Very near this hole will be more of them. One is probably marked by an arrow pointing into concentric rings; this is line-in. Another is probably marked with a "lollipop" which represents a microphone; this is microphone-in.
Failing this, try reading the manuals for your computer. -
If you find out that you have a sound card, make sure that "line in" is not muted.
Adding to what "up" suggested. Open your Volume Control Settings.
Select Properties->Recording and check if your Line In is enabled. If you have a microphone connected, ensure you disable this in your recording controls to prevent stray external sounds from being recorded into your capture.
Descriptions for Audio Effect Plug-ins-- Vegas 6.0d
By solarblast in forum AudioReplies: 4Last Post: 15th Nov 2008, 23:39 -
video and audio time dont match?
By just in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2008, 20:58 -
My Audio Isnt working, Dont know much about Audio, Just that my............
By UmmAddan in forum AudioReplies: 0Last Post: 12th Aug 2008, 20:11 -
any way to capture 2 channel audio when VCR only has white plug?
By cduval04 in forum Capturing and VCRReplies: 6Last Post: 20th Jan 2008, 16:55 -
Is there a such thing as a headphone plug adapter from a rca audio port?
By moomooemu in forum Newbie / General discussionsReplies: 10Last Post: 11th Dec 2007, 01:48
