Hi,
I am new to this subject, please excuse me if my question been discussed before. I am trying to backup some Region 3 DVDs I brought oversea. They are original, not pirated. I used DVDFab HD Decrypter 4 (4.0.5.0), trying to backup and remove RC protection. Backup seems fine, but I could not play back the movie using Videolan VLC Media Player. It looks like RC protection still on.... The best I can describe the resulting play back screen is like small random part of the picture are viewable, but the rest are small squares...
My question is do I need to use another software to play back non Region 1 DVD after I backed up to my PC?
The DVD is Region 3 NTSC DVD-9.
Many thanks in advance!
It's not a region code issue.
I guess the original DVD work fine in VLC?
How do you play with VLC? Select File->Open Directory and choose the VIDEO_TS folder.
Try play with something else like Media Player Classic. -
No, I could not play the original DVD with VLC because my DVD drive has Region code set to 1. I am not sure if the drive could be set to region free or not. This is the reason I want to back up the DVD to my pc, hoping in the process will remove the RC protection so that I can watch the movie on my PC. Is my DVD drive Region code set to 1 has something to do with the result of the backup?
I have not tried Media Player Classic before, will give it a try. Thanks for your quick response. -
I can view the backup movie on my PC using Media Player Classic, but no sound. I will try the backup process on another Region 3 DVD and see.
In regard to Media Player Classic, you might try installing AC3 Filter. That might help with the audio issue.
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 10:25 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 21:10 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Total Newbie -- Best/cheap way to rewrite a Region 2 DVD to Region 1
By jteselle in forum Newbie / General discussionsReplies: 6Last Post: 3rd Nov 2009, 11:49 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58
