I wanted to backup one of my DVDs to XviD using DGIndex (version 149) and AviSynth (for the video). The video part was OK. The problem were the audio files since I had ripped my own DVD with DVD Fab Decrypter, then re-authored it with DVD Shrink (I put the 3 VOB files I wanted, one after the other one - nad because DVD Fab had created a mess with all VOB files - some included part of the extras and the beginning of the main movie on the same file ).
After re-authoring the DVD, I used DGIndex to index the files and create a project which would be used on a script to AviSynth. DGIndex has an option to demux all tracks and that's what was done, but it demuxed 2 main AC-3 files. One for the main video and the other one for the extras. Question: what can I use to join these 2 AC-3 files? Thanks in advance.![]()
The search function still works:Originally Posted by Cunhambebe
https://forum.videohelp.com/topic342266.html?highlight=join%20ac3
I usually run the joined ac3 file through ac3fix just to help ease my mind that the join went OK. -
Thanks for your help. I tried the search function - but found no responses (maybe my query was wrong) so I decided to post this topic. Sorry. I'll try your suggestion, thanks lot - let's hope the audio is not out of sync.
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
join MZ TS files together
By dude905 in forum Blu-ray RippingReplies: 8Last Post: 3rd Apr 2011, 21:48 -
How can I join 2 sup files?
By EC in forum SubtitleReplies: 3Last Post: 25th Mar 2010, 11:51 -
2 movie files, 2 sub files. Need to join them into one
By andre477 in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 21:03 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
