Hey guys,
I have been using MTR for awhile and made copies of my original dvd's on to a Maxwell dvd-r's. But after a few times of playing the copy they stop working. I'm starting to think if its a good idea to rip the dvd's to a external USB hard drive and play it from the hard drive on my mac or on TV via the Mac or something like that.
What do you guys think? if anyone is doing something similar
Also I've been using my Philips dvp642 player for few years and its aging. What's a kick-ass DVD player in the geek circle these days?
That is a very good idea. Video contents (both SD and HD) stored in USB hard drive play very smoothly on a connected PC. I used to create DVDs for my home movies (family videos) but have stopped doing that. The DVD burning process is painful (long and unpredictable crashes). Even after you successfully burn DVDs, many of them are choppy on certain DVD players. Also, they tend to rot over time. I now have all of my home movies stored in USB hard-drive. The back up process is also very convenient, one can back up the contents to another USB hard drive in a hurry.Originally Posted by mercuryguy
I had a similar problem with a batch of Maxell DVD-R's. I thought my DVD Recorder had gone on the fritz. I then stumbled on the following page for Recordable DVD QualityOriginally Posted by mercuryguy
I have quit using anything but Taiyo Yuden DVD-R disks and have been happy with them. Not sure if you are experiencing the same problem as I have, but check out the media quality for good measure.
Cheers, Brent[/url] -
Thanks for the replies.That is a very good idea. Video contents (both SD and HD) stored in USB hard drive play very smoothly on a connected PC. I used to create DVDs for my home movies (family videos) but have stopped doing that. The DVD burning process is painful (long and unpredictable crashes). Even after you successfully burn DVDs, many of them are choppy on certain DVD players. Also, they tend to rot over time. I now have all of my home movies stored in USB hard-drive. The back up process is also very convenient, one can back up the contents to another USB hard drive in a hurry.
Do you copy them after the MTR process or After MTR, run through DVD2oneX and then create image file and then transfer?
What USB drives do you recommend? Is firewire faster? or which is the fastest ?
Thanks. -
I rip using MTR, then compress with DVD2oneX, then burn/copy that and delete the original.
A triple interface drive with Firewire 400, Firewire 800 and USB 2.0 is what I'm looking for.
Probably one of those Lacie All Terrain orange looking portable ones that are bus powered. -
You can rip DVDs using any sofware of choice, shrink them, and either (a) leave them in the original file structure, VIDEO_TS, or (b) create an ISO file, and copy them to the external hard-drive. Either way would allow you to play the videos on the hard-drive.Originally Posted by mercuryguy
Firewire is certainly faster than USB 2.0. I bought the WD hard-drive (MyBook 500 Gb) with USB/firewire combo. The videos (both standard-def and high-def) play smoothly using either connection. Firewire is useful for backing up the whole hard-drive (much faster than USB). The USB/firewire combo is a bit more expensive than just USB.
Ripping my dvd's to external hard drive......
By nodollas in forum DVD RippingReplies: 11Last Post: 30th Jan 2010, 10:57 -
What are all these files in my external hard drive?
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 18th Jan 2010, 23:54 -
external hard drive
By alintatoc in forum ComputerReplies: 20Last Post: 26th Sep 2009, 19:54 -
External Hard Drive > TV?
By jason in forum Newbie / General discussionsReplies: 36Last Post: 12th Mar 2008, 09:32 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 08:47
