Closed Thread
    Jun 2004
    Canada
    Okay, so I am trying to embed this movie file into my website and nothing seems to be working.
    This is the code I'm currently using:
    <OBJECT CLASSID="clsid:02BF25D5-8C17-4B23-BC80-D3488ABDDC6B" WIDTH="480"HEIGHT="286" CODEBASE="http://www.apple.com/qtactivex/qtplugin.cab">
    <PARAM name="SRC" VALUE="3x-Screener.mp4">
    <PARAM name="AUTOPLAY" VALUE="true">
    <PARAM name="CONTROLLER" VALUE="true">
    <EMBED SRC="3x-Screener.mp4" WIDTH="480" HEIGHT="286" AUTOPLAY="true" CONTROLLER="true" PLUGINSPAGE="http://www.apple.com/quicktime/download/">
    </EMBED>
    </OBJECT>
    Someone told me that it loads everything first and THEN plays - but perhaps it just doesnt work.
    You can see the actual page its loading on here:
    http://imagearts.ryerson.ca/aschoales/portfolio/films/3x-watch.html
    UPDATE: Did some poking around and im thinking that perhaps the server im using has blocked mp4 because if i try to load it directly/download it loads a cannot display page - if i change the extension to .mov it lets me download it just fine...
    but it still wont let me embed it - even if it's set to .mov
    :: ehmjay.
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    the path to the mp4file should read:
    http://something.something.server/containingfolder/file.mp4
    in the embed tag.
    this in case the Server does a weird kind of resolve....
    They shouldn't block it unless it is over a certain size, or
    if you have size restrictions /bandwidth restrictions on your server.
    ask your webmaster as to what he says....
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Jun 2004
    Canada
    found out about the mp4 issue - its something the admin has to fix (just tell the windows server to allow mp4)
    I tried switching the extension to .mov and embedding that and still have no luck... even after following your advice.
    anyone else know?
    :: ehmjay.
  4. Member terryj's Avatar
    I recreated your page here:
    http://members.cox.net/terryjackson1/adam.html
    I did as a test both .mp4 and .mov. Both embed fine.
    I would look at either:
    1. the size of your files--my two samples are less than 10kb a piece.
    Could be size constraints on your webspace or bandwidth
    2. Your Webmaster not setting correct mime typing for .mov or .mp4
    But the example I gave you works fine as far as the html goes....
    Urban Mac User
  5. I'm a MEGA Super Moderator Baldrick's Avatar
