I have just started burning DVD's so I can show them on my TV. I just completed the first one and the sound and quality are good. The only problem I have and don't like is that the DVD video plays through and then immediately starts palying the same video over again. I would like it to stop after it plays once like a DVD movie. I am burning them in a DVD_NTSC format which I assume is correct for playback. Any suggestions appreciated.
That's an authoring issue. If there's no menu at all, I guess it's up to the player to determine what to do once the movie has finished (if it's not authored to repeat). If you have a menu, you can author the DVD to return to the menu after finish. What did you use to author your DVD?
/Mats -
Mats is right. It's an authoring issue. What did you use to make the DVD? The only program I ever used that did this by default was the ancient DVD Maestro program.
It might be possible in IFOEdit to fix this problem, but I don't know what would have to be changed to fix it. The forums at http://www.doom9.net might have an IFOEdit expert who can help you, assuming nobody here knows how to fix this problem. -
DVDRemake: add 'Exit' command (from Jump/Call instructions dropdown) to the beginning of Post commands list of the last PGC.
Thanks for the answers. The only problem is I am a newbie and so am not familier with DVD authoring. I made the DVD using AoA DVD Creator. Looked at the help menu and it doesn't seem to have anything about where I can force the DVD to just play once. Is there a better DVD creating software, without a steep learning curve out there that I should use instead of AoA DVD Creator?
It all depends how much do you want to get involved. There is lots of software which will let you make simple or complex menu DVD. Just check this page under Authoring DVD.
https://www.videohelp.com/tools
SOS- Registry Help Needed: Stop Repeating Windows Installer (XP)
By ahhaa in forum ComputerReplies: 6Last Post: 20th Nov 2011, 06:41 -
Footage repeating, skipping, etc.
By koberulz in forum Authoring (DVD)Replies: 28Last Post: 9th Jul 2011, 22:42 -
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
Recorded TV MPG file repeating frames.
By sambat in forum DVB / IPTVReplies: 8Last Post: 20th Mar 2011, 04:48 -
Making a DVD with auto repeating chapters
By JJ72 in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2011, 09:59
