This has probably been asked before or I'msure the information is provided somewhere on this site, but I'm a layman and i find most of the info deals with burning dvds on your pc. how do you take a dvd recorder and record off a dvd player? please someone explain!!! i need to copy a dvd-r movie for someone and don'tknow how
You do that with your PC, not a DVD recorder. Put the DVD-R in your DVD reader in your computer, start DVDDecrypter in ISO Read mode. Once ripped to ISO, put a blank DVD-R in your computer DVD writer, and again use DVDDecrypter in ISO Write mode.
/Mats -
The vast majority of commercially produced DVDs are copy protected. All stand alone DVD recorders will respond to that copy protection preventing your making a copy. The only way to copy a copy protected DVD is through your PC using the software that is discussed on this forum.
SMK -
If your DVD Recorder has a hard drive, you might be able to copy the disc to the hard drive then burn a copy. Check the owners manual for instructions.
What matssaid....
If you don't have a dvd burner in your pc just hook the dvd player into the dvd recorder and record it, just like copying a vcr tape, cassette tape, ect.
But for $30.00 you should prob. pick one up if you don't have one
Ummmm...Originally Posted by RoyGBiv-inRI
Originally Posted by AlastairSim -
Not entirely accurate. Some older DVD players (like my workhorse Malata 700) were "chipped", to be both region and MV free. I could play just about any commercial DVD (that would play in this player -- and that would likely be over 99% of them), and from there go straight in to my Pioneer DVDR. (The regular setup I have is not configured that way, so I'd have to move some cable connections around. I might also want to get the TBC into that chain.) That said, I think doing this in the computer would generally be easier, and provide more control and versatility. I'm not sure how the quality comparison would come out, but I suspect that a strong edge would go to doing it the computer way, as this is a straight digital copy, without all the intervening circuitry.Originally Posted by RoyGBiv-inRILooking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
DVD Recorder will only record when TV is switched on
By jiminwatford in forum DVD & Blu-ray RecordersReplies: 23Last Post: 18th Apr 2011, 15:03 -
HELP PLEASE!! Can i record an AV channel on DVD recorder HELP PLEASE
By Lilman02 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Apr 2010, 15:55 -
any way to record from TV to DVD recorder?
By thedriver2200 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 10th Jun 2008, 13:37 -
DVD Recorders (VHS to DVD Recorder then record raw footage and finalize)
By aeafisme23 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 16th May 2008, 14:39 -
Can a HDD MiniDV record a DVD by connecting with a DVD player/recorder?
By coody in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Jan 2008, 10:01
