I've got one of these and it's been great. I'd like to upscan but right now whenever I go to the info page I don't see anything about 1080, only 480. I've got macrovision, edid, and HDCP turned off and I have the latest firmware I think. Is there something else that I need to be doing?
Many DVD players won't upconvert copy protected discs (commercial discs).
Also, depending on your TV, it may be totally irrelevant. If you are using an LCD or plasma TV for example, ALL inputs are automatically upconverted / downconverted to the native resolution of the display.Google is your Friend -
My tv takes 1080. I was hoping to get it to output at 1080 instead of 480. So far no luck.
I know nothing about the DVB418, nor did you mention what model of TV you have, but Krispy Kritter is right. I am getting excellent results from a cheap piece of crap Philips DVP-642 DVD player which can only output 480p. My Samsung HDTV upconverts it itself to 1080p and the results are excellent. Unless this DVB player has a Farjouda chip, your TV may do a better job of upconverting anyway, so you may not be missing out on anything.
I have a digimate 27 inch lcd. It apparently supports 1080i and when I plug in my hd reciever I get it at 1080. That's why I was asking. I did try it with a non-copyprotected disc but it still didn't work.
How is it connected to the LCD-TV?Originally Posted by kruuth
I don't see a 27" in their line? Which is it?
http://www.digimate.co.uk/index2.htm
Most upscaling DVD players won't upscale a commercial DVD. Try a DVDR you made.
Some upscale over analog components or HDMI.
Others only upscale over HDMI. Some of those first require an HDCP handshake.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Supporting 1080 input is totally irrelevant as I noted above. You need to be concerned with your TV's native resolution. Most smaller LCD's are 720P and use a native resolution of 1366x768 (although they all support 1080).
Basically, in your case (assuming your TV is 1366x768), you will be taking 480P content and upconverting to 1080 in your DVD player, your TV will then take your 1080 input and DOWNCONVERT to 720P (your native resolution).
Of course, this is a side topic of the original issue. As I noted above, most players do NOT upconvert commercial discs.Google is your Friend
Upconvert SD to HD using software?
By videomaniac in forum Video ConversionReplies: 16Last Post: 21st Feb 2011, 01:22 -
Mv DVB418 is dying. Need recommendations for replacement
By kruuth in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Feb 2008, 10:54 -
upconvert to 1080p
By ultrabigal in forum DVD & Blu-ray PlayersReplies: 8Last Post: 29th Nov 2007, 19:58 -
Phillips Upconvert DVP3960/37
By LanxS in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2007, 23:28 -
LG DVB418 Tray locked shut!
By ness395 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jul 2007, 16:53
