Hi,
I am trying to find a way to cut an AVI such that the bytes in the resulting video—the part that is kept aside from the header, etc.—are identical to the original. I have been using the v/nandub, etc. applications in direct stream copy mode to cut videos for a long time, but the videos that are made are not identical. In other words, when you do a binary comparison of the two files, you should get a few small differences in the header or whatever, and the original should be longer, but otherwise the files should be identical (ie, changes could be made with a hex-editor, like you can with an MP3 as long as you cut on a frame-boundary).
For example, let’s say that I have made a large video (eg 1GB), and am sharing it via FTP, P2P, HTTP, etc. (basically any resumable transfer method). I then decide to cut out the last minute of the video. Doing it like I have been doing causes the file to be drastically altered even if the resulting image and sound are identical. This means that people who have gotten only part of the video cannot use what they have and must start downloading it all over from scratch (and thus wasting my bandwidth).
Also, sometimes I run into the situation where I need to cut a video where there is no keyframe but cannot figure out how. I know I’ve done it a couple of times by chance with one of the dub apps and with another commercial app, but it never works when I purposely try to do it. Will re-deriving the keyframes work? If so, it will create a non-identical file right? This isn’t a high priority; I can keep a little extra.
Thanks a lot.
Results 1 to 15 of 15
I can make a suggestion for the transfer of large files: cut it into smaller pieces using archival software like winrar, winzip etc...The resultant re-assembled file will be identical.
You can specify an exact size, add a password, add .sfv and recovery records for checking.
Furthermore, there are many free hosting sites, some which have unlimited bandwidth and duration of hosting. You would only have to use 1x upload bandwidth. -
Thanks for the suggestion but you can’t really compress videos so there’s no point in using WinRAR, etc. over a standard file splitter.
I don't think he is suggesting WinRAR for compression, just archiving into small pieces to be reassembled as a whole file when Un-RARed. If you add a .sfv file and a PAR file, you have redundancy and error checking. I have used QuickPAR with Usenet downloads of RAR and PAR files.
But, I more often cut them at keyframes with the keyframe icon button in VirtualDub. When you use 'File>Open video file...' in VD, you can check the 'Ask for extended options after this dialog' box at the lower left and in the next menu, select 'Re-derive keyframe flags'. -
Syntech, you have a bunch of misunderstandings. What you wan't basically isn't feasible.
Most P2P software uses hashes to identify files. If even one byte is different, or the length is different, the new file will not be identified as the same file. An incomplete FTP or HTTP transfer might be able to resume if only the end of the file is cut off but...
The AVI headers include lots of stuff that will vary depending on the program that created it and the nature of the video. So using a tool like VirtualDub or AVIDemux to trim the end off the video will create more changes than just cutting off the end of the file.
The end of an AVI file, with high compression codecs like Divx and Xvid, has a list of keyframes. The list will change if you remove frames from the file. If this list is missing, most players won't be able to play the file. -
Originally Posted by jagabo
P2P apps don’t use a single hash per file, they hash and compare smaller blocks, so if the new file is mostly identical to the original, then only a bit from the beginning and/or end of the file needs to be re-transferred.
Ultimately, it is not even a transfer issue, I just want to be sure that the cut video is exactly identical in quality to the original, and if every single frame has been changed, then how can I be certain of that? -
AVISynth has the tools for frame by frame comparison of video files. Here's one way you can compare frames:
Code:# compare two videos v1 = AviSource("video1.avi") v2 = AviSource("video2.avi") sub = v1.subtract(v2) substrong = sub.levels(112,1,144,0,255) return StackVertical(StackHorizontal(v1.subtitle("original"),v2.subtitle("encoded")),StackHorizontal(sub.subtitle("Difference"),substrong.subtitle("Difference amplified")))
Here’s an analogy: if the original first frame contained 12/6 giving a result of 2, I want the first frame in the output file to be 12/6 as well, not 18/9 even though it gives the exact same results after decoding. -
I think a better example might be that 5/2 and 4/2 will both give 2 as an integer result. But by using 4/2 instead of 5/2 some precision has been lost which might otherwise have been used. I don't know the codecs in enough detail to know what might change within the compressed data during a remux. But some of the remuxers can't even decode the audio and video they're working with so it seems unlikely they will change anything that effects the way a decoder will decode them. -
I am even more concerned about the dub apps’ output now because I just opened some test videos in Nandub and saved them—no cutting—with both audio and video set to direct stream copy (in other words, just copy the file, don’t alter it in any way), yet the resulting files were drastically different (and not just the metadata). Sure, the frames may be identical when you display them in a player, but the binary data is quite different, so you cannot compare it to check for corruption.Is there perhaps a setting or something that would give the same file (hopefully including not modifying the metadata)? I have attached one of the small ones to try.
catandceilingfan.avi -
I took your little video and remuxed the video into a new AVI with VirtualDub called A.AVI. I then opened A.AVI with VirtualDub, cut the last frame, and saved as a new file, B.AVI. Both files were identical except for a few bytes in the header, a chunk size somewhere in the middle, and about 6000 bytes at the end.
I took your video and remuxed it with AVIDemux (audio and video). I took that file and remuxed the video into a new AVI with VirtualDub, as above. The output was identical to A.AVI. -
I'm not a expert with all this, but what jagabo said here seems important to me:
And I'm only suggesting a program like WinRAR for distribution of a video in smaller parts over the internet, especially with a slow connection. I dislike having to rejoin RAR files, but it is a viable method for internet distribution. -
Or if you prefer, 7-Zip is freeware and understands RAR. Or Google for unrar to find many other, free, ways.
I can use DOS commands, but many have a deep phobia about it. You'll get a lot of people complaining and asking you to explain this over and over if you offer files like that.
You really can't slice up a video file with a hex editor and expect to get a valid file, unless you know a great deal about the data structures. -
Are I-Frames the same as Keyframes?
By leopard in forum ffmpegX general discussionReplies: 4Last Post: 1st Aug 2009, 07:23 -
cutting/joining x264 clips won't reencode with keyframes - a blurry mess!
By forgotpassword in forum EditingReplies: 1Last Post: 13th May 2009, 21:01 -
Same dvds but not all play identical
By aliefjoker in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2008, 10:44 -
Why do i get 2 identical subtitles running over each other?????
By Arwen-Katie89 in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2007, 17:41 -
Why won't identical hard drive work in another identical PC?
By rijir2001 in forum ComputerReplies: 8Last Post: 25th Jun 2007, 09:12
