i've been using FFMPEGX for a little while now and i'm kind of stuck on what to do.
i'm trying to convert a single AVI file to DVD using the ffmpeg mpeg2 conversion process featured on the how to page. i drop the file to the source. heres the specs:
video: mpeg4, yuv4204p, 512x288
audio: mp3, 48000 Hz, stereo, 64 kb/s
target format:
to: dvd
video: ffmpeg mpeg2, 720x480, 4000 kbps, 23.976 fps, no crop
audio: ac3, 48000 Hz, 448 kbps
i then load the subtitles using the filter tab and load a .sub file into the load subs area. at this point, everything is fine and the subs sync up perfectly with the video during preview. my problems start after i have encoded the file. the only thing that is produced is a single mpg file and no VIDEO_TS or AUDIO_TS folders to make a dvd with.
i guess my question is, what the hell am i doing wrong with this setup? i've followed all instructions to the letter and so far nothing has come of it. thanks for any and all help with this.
Results 1 to 14 of 14
Use the tools menu under author and input your mpg file that you converted and your subtitle (if it was not hardsubbed in during your conversion) and hit the author button, which will create a folder containing the VIDEO_TS folder. If you need to create an image file to burn your DVD you can also do that with the img tab under tools. Check with DVD Player before burning to make sure the result is what you wanted.
When you author a DVD with ffmpegX and include an .srt file, the resulting subtitles are soft and usually turned off when you play the video in DVD-player. Did you check that? Silly question maybe, but I've seen quite a few people not think of this, as they expect the subs to be hard.
Maybe someone can help me. I had the EXACT same problem, I followed the instructions from the site to convert an avi file to a dvd, but only the mpg file and NO VIDEO_TS or AUDIO_TS folder was created. After having read this page, I tried to author the MPEG file, to create the VIDEO_TS folder, but the information in the progress bar says:
/Users/vincentwouters/Documents/my film.avi.ff.mpg.xml:3: parser error : xmlParseEntityRef: no name
Desktop/My film
ERR: Error in parsing XML
And so, the folder weren't created. Anyone has an idea? Thanx in advance
I've been trying to get subtitles to work on a transcoded Video_TS file, but they haven't been loading. I started with an DivX, and transcoded with ffmpegx to .mpg and Video_TS. I load the .srt file in the filters tab. The subtitles are not on the transcoded files though. When I preview in the filters tab they are there and I am able to edit them. I do get an error message when closing the mplayer regarding the subtitle file:
FIXME:Hardenabling SSE and SSE2 without detection
and then it shows the source and says doesn't look like font description, Cannot load font, Cannot load subtitles
If anyone could shed some light on this subtitle problem, it would be greatly appreciated.
This is not an error and totally unrelated. Every Intel chip in a Mac has the SSE and SSE2 instruction sets (Intel introduced SSE2 in 2001 for the Pentium 4), so it is pretty safe for software to presume these useable and enable them without trying to detect them first.Originally Posted by floggens
If subtitles were included in the VIDEO_TS folder, they would be off by default. Use your remote or the subtitle button in the console in Apple DVD Player to view the subtitles.Originally Posted by floggens
It could be helpful to be able to read the full text of that...Originally Posted by floggens
How to include subtitles when converting avi > mpeg > dvd ?
By buzzsaw in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2011, 11:05 -
Converting DVD to AVI - keeping subtitles
By Matthew1404 in forum DVD RippingReplies: 2Last Post: 11th Mar 2011, 17:48 -
How do I keep subtitles when converting dvd to avi or mpeg?
By Haopengyou in forum Video ConversionReplies: 6Last Post: 20th Sep 2010, 20:19 -
converting subtitles from avi to dvd???
By denze1 in forum ffmpegX general discussionReplies: 1Last Post: 11th Feb 2010, 12:39 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23
