A VCD can have several features and menus. So in general it's more complicated than just a direct translation of one single MPEG.Originally Posted by tomlee59
Results 31 to 48 of 48
VCDImager Authoring Guide Series @:
http://download.videohelp.com/vitualis/index.htm
I learned a lot from it
Not going to stretch my epenis over an old VCD format, but you should learn a thing or 2 about a thing or 2Originally Posted by tomlee59
. The bin file doesn't contain the information about the actual image, it's a raw dump of info. If this was a plain iso9660 format, then yes you can simply burn the bin file. A regular ISO image only stores 2048 sectors, with the extra 304 used for error correction, a (S)VCD uses all 2352 sectors. If you where to just burn the bin file you can expect the (S)VCD to not start at the exact beginning, and end before the actual playing time (A 70 minute movie becomes 66 minutes). This is a well documented problem with older versions of Nero (pre 5.5), which were quilty of doing exactly what you decribe as being perfectly ok to do, ignoring the cue file and only burning the bin. Programs like VCDGear, binchunker, and ISOBuster have options for you to chose the bin mode so that it can handle the correct format.
Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
AlanHK -- Yes, you're absolutely right, of course. If the structure is more complicated than just a movie, the cue sheet is needed. Thanks!
Disturbed1 -- I definitely have more larnin' to do, but perhaps I'm not alone in that need. In the case of a simple movie, if the burning app knows in advance it's to create a VCD (burn in Mode 2 -- as explicitly stated), then the bin file has all of the information needed, in principle. A Mode 2 disc backs off on the amount of error correction to allow 2336 bytes of user data in the 2352-byte sectors (not 2352 sectors). A normal (mode 1) disc has 2048 user bytes per 2352-byte sector, allowing much more error correction. Instructing the burning app to use Mode 2 avoids the Nero problem you describe. -
tomlee the problem becomes not a lot of apps can burn mode2/FORM2. it's different from a standard mode2 burn. NOT 2336 but 2332 bytes/block.
I thought that the optional 4-byte EDC code is used in VCDs (making it 2336bytes/sector), but apparently not. Do you happen to know what they use that extra space for?
just to mess with burning apps
if it's not burned correctly they lose the ability to seek - no ff rw or correct chapters and often the audio goes out of sync.
crap it's been so long i got the numbers wrong it's 2324 data and the extra 8 bytes were reserved for interactive data, called a subheader and an optional 4 byte edc.
The different Modes that can exist on CD :
Audio (2352 bytes / block User Data, 2352 Bytes / block Raw data)
Mode 1 (2048 bytes / block User Data, 2352 Bytes / block Raw data)
Mode 2 (2336 bytes / block User Data, 2352 Bytes / block Raw data)
Mode 2 Form 1 (2048 bytes / block User Data, 2352 Bytes / block Raw data)
Mode 2 Form 2 (2324 bytes / block User Data, 2352 Bytes / block Raw data)--
Same here.Originally Posted by tomlee59
It's been so long since I've even made a VCD, I may just have to break out my Philips VCD Toolkit, and a bottle of aspirin.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
I could have sworn that VCDEasy 1.1.5.2 (last free one) came with CDRAO or something in the package. It already burned.
i think the last version without media player integration was 1.1.2 it can still be found in weird little places like this.
http://64.233.169.104/search?q=cache:Lt_VwWg7IaAJ:www.hpartsch.de/Downloads/site10.htm+VCDEasy+1.1.2+download&hl=en&ct=clnk&cd=48&gl=us--
I know. But it didn't work.Originally Posted by aedipuss
It was a few years ago, but I think it was just that it was written for old versions of Windows and old CD burners. So rather than burn coasters trying to work out if it was possible to make it work, I just used a more recent burning app, Fireburner.
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 11:51 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 04:07 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
chapters with procoder 3
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 17th Oct 2007, 12:20 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 22:25
