How can i set new root menu with DLP?
i have 3 VTS's and one of them is (obviously) the root menu, now, i want to set other VTS as a root menu...
can it be done?
Thanks in advanced!
The first menu in any VTS is the root menu for that VTS.
To change which VTS becomes the default VTS when the disc is inserted or the title button is pressed, go to the Connections screen and draw a new connection from the Title object to the Root menu of the VTS you want coming up first.
I don't know of any way to easily change the order of the VTS's themselves.Read my blog here.
I've already tried that...Originally Posted by guns1inger
nothing happens when i'm drawing connection from Title Menu/First Play to the VTS...
but i did find other simple way to do it from Connections window...
i just right clicked on the VTS and chose "Set Menu As Root"...
i dont know how i missed it.
thanks for your help! -
I had no trouble changing the title and first play connections by drawing new ones.
Set Menu As Root only changes the root menu for that VTS, not for the disc. If the menu is in the first play VTS then it will become the root menu for the disc, however if the VTS is not the first play/title VTS, you haven't changed the root menu for the disc.
Go back to the connections screen and see where the First Play and Title objects connect.Read my blog here.
isn't it the same thing?Originally Posted by guns1inger
cause i only have 3 VTS's on this disc... there's no any VMG's...
they now connect to the the one i set as root...Originally Posted by guns1inger
so i guess it will be fine... -
Each VTS has a root menu. The root menu for the disc, if you have no VMG menu, is the root menu for the first play/title VTS (and these could be different). So if you have three VTS, you have three root menus, and two of which could be the disc root menu.
Read my blog here.
how do i create a multi page root menu.
By visualhippocracy in forum Authoring (DVD)Replies: 2Last Post: 27th Mar 2011, 14:02 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 18:37 -
PGCEdit question: setting menu button highlight positions for letterbox
By Alex_ander in forum Authoring (DVD)Replies: 10Last Post: 5th Jun 2008, 11:55 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
DLP: Combine Switched Menu with Motion?
By GangstaRap in forum Authoring (DVD)Replies: 4Last Post: 15th May 2007, 08:52
