Hi I'd like to improve the DVDR's I'm making with a image or label has anyone veiws on the methods.
1. Casio disk printer. Seems to be a thermal printer gives basic text and image. Don't know if it can be used on created disks as the heat could blank the disk?
2. Inkjet. I currently use silver disks and I'd need to get in some printables, not to mention a differnt printer.
3. Inkjet labels. Seems the simpler method as any inkjet and use on burnt disks. But has anyone had problems with them. I'm creating mostly VHS dubs and archiving them, so its no good getting good disks and dubbing well if the stickers start curling up and jam in the player!
Cheers.
Results 1 to 15 of 15
My vote goes with inkjet printables. I use white TY's and never have any issues. I used to use sticky labels but had problems with skipping and freezing.
I found a Casio Disk Title Printer at the local thrift store sealed in the box for $8. These go for around $50 online. I am very happy with it. The software to use it on the PC gives some more options but the software is crappy and confusing (to me anyway), I just use the printer without the PC to make quick decent looking CD labels.
http://www.amazon.com/Casio-Printer-Qwerty-keyboard-CW-75/dp/B0000BV1LH -
Personally, I use this printer
http://www.newegg.com/Product/Product.aspx?Item=N82E16828104523&Tpk=d5160
with this media
http://www.supermediastore.com/vebatim-white-inkjet-printable-8x-dvd-r-47gb-media-free...-shipping.html
and this software
http://www.acoustica.com/cd-label-maker/
The quality is, IMO outstanding. -
Read the 3rd stick down in the MEDIA forum....Originally Posted by StuR
https://forum.videohelp.com/media-f27.html -
Stay away from stick on labels fro DVDs. Do a search of the forums here and you'll see an exhaustive series of threads that all come to the same conclusion - that in a large number of cases, sticky labels cause playback problems.
I use inkjet printable with an Epson Stylus printer (can't quite recall model number) that was $90. very happy with the results and gives a more "professional" look than stick on labels. I only use that printer for CDs and DVDs so the ink has lasted quite awhile. It might take a couple of tries to get that first calibration right but after than its a breeze. I'm sure other brands produce just as good results for the same price. -
I have hundreds of stick on label and no problems over the years.
sharpie for me
Donadagohvi (Cherokee for "Until we meet again") -
Do not use sticky labels at all for any reason.
I consider disc labeling a waste of time anyhow. If you want to make something nice to go with the disc, put your effort into a nice DVD case. Those get up to several minutes of viewing time, while disc art can only hope for several seconds at most. Lots of effort for little return.Want my help? Ask here! (not via PM!)
Same 3 things I use along with the TY's, works great.Originally Posted by powerpc123
Sharpie Retractable for one handed operation (you hold the disk in your other hand....).
http://www.sharpie.com/enUS/Product/Sharpie_Retractable_Fine_Point_Permanent_Marker.html -
It's be nice to have a small plotter where you load the disc, a sharpie, and it writes on the disc in very nice handwriting. Or maybe a leroy with a sharpie attachment.
Darryl -
Sharpy + a calligraphy class at the jr college.
http://www.kiva.org/about -
I’ve been using the Casio disk printer (a CW-50) for several years. [I got it for $40- $10 rebate]. I have the USB model that needs a computer. Many branded disks can print with this. However, it prints funny if there are lines on the disk. (I just align the disk to print in a blank area)
I’ve never had any issues with heat.
I fooled around with some disks when I first got the printer– (because the thermal transfer method had me curious) You would have to get the disk very hot to mess up the printing. I'd worry about damage to the disk itself before I'd worry about “blanking” the label.
It can be printed on almost any type disk-- the issue seems to be how smooth the surface is. Some disks don’t take the transfer well. Sometimes you can print twice if the first pass did not work. Ideally, use disks specified for thermal printing– (these come in silver and white). Also the disk is completely impervious to water– unlike inkjets. You can also ask where you buy the disks if they can be printed with a thermal printer. I’ve found many work although they’re not specifically designed for it. The Casio cartridges are inexpensive and they do not dry out or clog. Printing ‘dries’ instantly. Prints start about at $0.14 and up per disk-- depending on how many "areas" you print.
Although you can use any font/style on your computer, I tend to use only the clearest fonts Arial, Arial condensed, Impact, Universe Condensed, CG Omega for printing on these disks.
People often comment on how crisp and professional the writing is– the graphics that you can use with this look cheesy to me (so I don’t bother with them).
http://tinyurl.com/yc6sgh
The Casio is not for everything but it is good for a lot of things where some basic text is needed. I think different models offer slightly higher printing resolution– (but I haven’t seen the need for it) as well as turning the disks automatically (you have to position the disk manually each time you print the various areas with mine)
Another printer you might consider is the Dymo DiscPainter– I’ve seen these in person at the retail B& H and they look impressive.
http://tinyurl.com/34yv75
The cost is about $0.40 a disk. The printer is pricey though. (nearly $300) However, all reports I’ve read is that it is much more reliable than inkjets that serve double-duty. As, I send out my photos for printing a printer that also prints on media isn’t a necessity for me.
Also at Amazon (there’s a bunch of reviews here too)
http://tinyurl.com/33onbj
I would also, second/ third about putting labels on your disks– it might be ok for DATA disks but not for disks that will be played in a DVD player. -
Thanx all, no time to answer all, but basically I'd quite like to have pretty disks but was sure i'd seen concerns with sticky label, now I now I did.
So I'll leave it for now and consider printable TY's if I produce some backup copies of the orig dubs.
Cheers for avoiding a time wasting diversion.
AccountKiller
By rcvalle in forum MediaReplies: 7Last Post: 7th Dec 2010, 22:38 -
3:2 Pull-Down and other telecine methods?
By Weef in forum Video ConversionReplies: 1Last Post: 20th Jan 2010, 21:23 -
VHS to DVD 4 methods?
By sonomablue in forum Capturing and VCRReplies: 73Last Post: 4th Sep 2008, 22:08 -
PIPO methods
By vlad247 in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Jun 2008, 03:43 -
PIPO methods
By vlad247 in forum ProgrammingReplies: 1Last Post: 12th Jun 2008, 19:41
