Q1 :: i have a video file in wmv format @ 800 kbps. if i increase its video bit rate @ 1600 kbps by encoding. does its quality also increases? by doing this i know size of the file increases.
Q2 :: Similary if i get an audio encoded in 192 kbps Stereo if increases it to 256 or 320 kbps does the quality of the sound increases.?
8)
1: Nope, reencoding it and increase the bitrate wont help. With some filters you might get "better" quality, like deblock and sharpening filters.
2: Nope.
Best is to find a better video source and then reconvert to the higher bitrate. -
Start with a nice flat shiny piece of aluminum foil, say 12x12 inches. Compress it down to a 1 inch ball. Uncompress it back to a flat sheet. Note all the wrinkles (compression artifacts). Compress it again, but this time only to a 2 inch ball (less compression). Uncompress it again. Does it have more or less wrinkles?
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
problem with video frame quantity
By solteimartia in forum Newbie / General discussionsReplies: 14Last Post: 29th Mar 2011, 06:25 -
I'm still on the first road I have a large quantity of DVD
By krrish in forum Newbie / General discussionsReplies: 12Last Post: 10th Sep 2008, 08:15 -
Subtitle quality after conversion
By cobalt in forum SubtitleReplies: 2Last Post: 4th Aug 2008, 11:29 -
Wal-Mart offering (limited quantity) HD-DVD players for $100 tomorrow
By ViRaL1 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Nov 2007, 07:14
