Hello, First time user here. Thanks for the help in advance. I've got a Sony handycam DCR-DVD92 and I'm desperate to pull video off of it to my mac for editing. If I get the Canopus ADVC 110 converter will I be able to pull video from it? All I've got is AV cables so I figure if I can plug the AV cables into the converter I can send it via firewire to my Mac. Just wondering if anyone knows this is possible. Thanks in advance. Brian
Wouldn't it be easier to copy the DVD from the handycam to your harddisk, and start editing from there?
they are mini-dvd's that can't go into the mac. the only output from the digital camcorder are rca cables. kind of ridiculous.
Yes your workflow is sound.
The camera since it only has analog,
will work like a VCR in that aspect,
going into the Canopus and then via FW into
your mac.
I assume that the the modes on the camera are
the same as any: Record, VTR (Play), and Off.
If so, then VTR mode will play back through
the analog cables just fine.
Now, you might think about cost: An external burner,
such as a Pioneer -112D in a firewire enclosure for
about $80 would be cheaper than a Canopus ADVC-110,
and would enable you to mount the mini dvd disc onto
your mac for ripping. Something to think about;
if all you need the Canopus for is an interface for the camera,
this might be a cheaper alternative. However, if you also
have VHS tapes to digitize, then the cost of the Canopus
would be justified, because their would be more to do with it."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Looking For Something Better Than a Sony Handycam DCR-DVD105
By PeripheralVisionaryX in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 21st Jun 2011, 13:11 -
Sony Handycam DCR-HC53E -- help!
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jun 2010, 17:52 -
Sony DCR-PC108E Handycam
By ckbasak in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 13th Jan 2010, 12:57 -
Will the Canopus ADVC 110 converter work for my Sony DCR-DVD92?
By briandk17 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 05:54 -
Sony Handycam - DCR-HC20E
By nzmikey in forum Newbie / General discussionsReplies: 4Last Post: 10th May 2007, 04:17
