I made a DVD and wanted to add chapters. I did this with Nero but about an hour into it the audio is about 2 minutes off. Without the chapters added the audio is just fine. Is there other software to do this as I found Nero too be a pain !
I changed your subject. Please use a subject that describes your topic better than just How do I. You can change it by click on the edit-button on your post.
Yep, just try convert with something else than Nero.
MKV stream extraction causing audio sync problems
By PlanetIndigo in forum Video ConversionReplies: 18Last Post: 29th May 2011, 22:07 -
Avidemux editing causing audio sync issue
By perdomot in forum EditingReplies: 0Last Post: 14th Sep 2009, 15:29 -
Add a intro clip onto a DVD to play before chapters apear NERO VISION
By cp_ozie in forum Authoring (DVD)Replies: 11Last Post: 25th Jan 2009, 18:04 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
Glitch In Video Causing Audio To Off-Sync
By Squid_uk in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 10:51
