Hi;
Not sure if this is the right category, I have following problem: I am using a software that allows me to do online live presentations using my webcam. The software uses the input from the cam. I would like to trick the system and show a video (wmv) file instead of the webcam.
Is there any software that can show the video and act as the camera device basically tricking the system?
	Online Coaching with http://www.clickalifecoach.com
 Send video email with http://www.helloworld.com/borntosucceed
	You won't likely find a tool for "tricking" your presentation software. There is no need/reason for anyone using the presentation software to not also need/use the webcam.
 Depending on your what you are actually trying to do, you may find other software for playing/streaming video files.Google is your Friend
	Is DV AVI the same than AVI? if yes then I am able to convert files to it. Would kind of solution do you have?Originally Posted by JohnnyMalaria
 ThanksOnline Coaching with http://www.clickalifecoach.com
	A upcoming new version of our software contains a feature called "Virtual DV" and it isn't tied to the main software. It works with DV format video. It doesn't matter where it comes from as long as it is DV. e.g., it can work with live DV from a camcorder, existing AVI files or even the DV output from an application.Originally Posted by borntosucceed
 It will depend on the input capabilities of your presentation software as to whether it will work with the Virtual DV.
 If you'd like to try it, please PM me and we'll take it from there.John Miller
  does ffmpegX accept wmv as input?By mark909 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Sep 2010, 14:02
  HandBrake + WMV/H.264 input = no joy?By x2x3x2 in forum Video ConversionReplies: 4Last Post: 10th Jul 2009, 01:29
  How to know input video file charateristics in NeroBy perfection in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2009, 03:02
  .WMV Input In MeGUI?By jatonblue in forum Video ConversionReplies: 9Last Post: 24th Jul 2008, 16:45
  Subtitle Input string not correct format/Input subtitle file error (SOLVED)By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
