What is your opinion of this SW? The biggest problem that I have with it is having to remember all the serial numbers, registration processes and keys required. Its a nightmare.![]()
I have a Panasonic HDC-SD1 that uses AVCHD codec for HD video. I have a 8gb SDHC card for the camcorder. It does not use a tape. Studio 11 Ultimate will edit this video, nicely.
Comments, please ?
Owner: Panasonic HDC-SD1 camcorder w/8gb SDHC card (AVCHD)
Longtime pinnacle users seem to be saying this is a lot more stable than version 10, which really is damning with feint praise as version 10 was an abomination.
Personally, I have heard enough horror stories about the various version of Pinnacle that I would not touch it with a barge pole.
However, if you are satisfied with it, and it does what you need, then be happy and use it.Read my blog here.
As I wrote some days ago I have discovered that Pinnacle 11 does not import timecodes. I am using DV and HDV (Sony HDR-HC5). I have to use Win Moviemaker for the import in order to obtain the correct info from the VideoCam. It is not very satisfactory that they omitted this important feature which was available in earlier versions. I will not dare to buy Pinnacle again.
I use pinnacle studio9 and i am very satisfied makes everything i need i thnik that 11 should be better give it a try
Bye
Pinnacle Studio HD v15 Ultimate
By Sokki83 in forum Newbie / General discussionsReplies: 13Last Post: 3rd May 2011, 22:59 -
Capturing with Pinnacle Studio Ultimate 14 or should use another programme?
By avz10 in forum Capturing and VCRReplies: 10Last Post: 28th Jun 2010, 12:09 -
Pinnacle studio 12 ultimate - can someone tell me what this guy did please.
By photonianpa in forum EditingReplies: 7Last Post: 12th Mar 2009, 08:40 -
Pinnacle Studio Plus 11 Ultimate soundproblem: Blobbing
By reposten in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2008, 13:53 -
Pinnacle Studio Ultimate v11.1
By joe8915 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2008, 07:58
