Long Version
If this has been posted before and resolved I apologize. I have read that it is possible to put up to 18 hours of video on one DVD with VisualHub. But you get no menus with that. So I am looking for another solution. I want to make a long DVD with menus. I have converted a series (8 hours worth) of cartoons from XviD to Vob files with the bit rate at around 1000kbyts/sec (is that right?) and when I go to put them in Toast 8 the dial says it will only take 1 DVD to accomplish this burn. I hit burn and it starts to multiplex then encode (I have the “Never Encode” option chosen) I have even taken some video out so that the space is right at 4GB and it still wants to encode. I am trying to avoid Toast encoding, (which can take a while and I have already done the encoding) any help would be greatly appreciated.
Short version
I want to make a DVD with 8-10 hours of video with menus. Source material would be Avi
Any help would be greatly appreciated.
R
Results 1 to 11 of 11
320x240 is not a valid DVD size. 352x240 is valid.Originally Posted by randolphsw
To add to the confusion, QuickTime Player will pretend that 352x240 MPEG-1/-2 files are 320x240. To read back the true size, drop the output file back on ffmpegX to see the video parameters in the Summary tab. If it really is 320x240, then I'm afraid you'll have to encode them again to a valid size.
For NTSC, the valid DVD frame sizes are 720x480, 704x480, 352x480, 352x240.Originally Posted by randolphsw
It depends on the frame size. Bigger frames need more bits to describe them, but it's not a linear relation. The [Best] button in the ffmpegX Bitrate Calculator should tell you good bitrates:Originally Posted by randolphsw
720x480, 3742 kbps recommended, which translates to about 150 minutes (02:30:00) per 4300 MB
704x480, 3659 kbps recommended, which translates to about 153 minutes (02:33:00) per 4300 MB
352x480, 1829 kbps recommended, which translates to about 290 minutes (04:50:00) per 4300 MB
352x240, 914 kbps recommended, which translates to about 523 minutes (08:43:00) per 4300 MB
The calculator defaults to 4000 MB per DVD, which is a bit safer number, but allowing 7% less minutes on average. The outer edge of a DVD±R(W) is the least reliable part, so maxing out a disc (4482 MB) may not be best practice. You also need to leave a bit of room for menus. YMMV.
Two-pass encoding (DVD ffmpeg preset, checkbox Two-pass encoding in the Options tab) will look a bit better on low bitrates, as it shifts bitrates to sections of the movie that need it the most, at the cost of twice the encoding time.
You can lower the bitrate a bit from the recommended number if you must, but "stay in the green", i.e. if the bitrate number is green, it is considered good (red for not enough, blue for too much). De-focus the bitrate field to see a color change. E.g., for 720x480, 3742 kbps is recommended, but 3368 to 4116 is considered 'good'.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Converting a DVD to AVI with all menus intact
By beatsntoons in forum Newbie / General discussionsReplies: 4Last Post: 17th Dec 2009, 15:39 -
Ulead DVD MF6 takes over 11 hrs to convert?
By Hondamaker in forum Video ConversionReplies: 2Last Post: 20th Jan 2009, 16:20 -
shortest way to encode 5.5 hrs of avi's using tda3
By cduval04 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2007, 13:38 -
creating a dvd using idvd 5 of a movie around 3 hrs?
By tab75-13 in forum MacReplies: 2Last Post: 1st Jun 2007, 07:12
