I received a box set of a tv series from Europe for Christmas. I came as 5 disks each with 3-4 episodes on it, 21 in total. They are in PAL and since my tv won't play them I wanted to convert them to NTSC. I am new to converting so I chose the long way I think since what I did was to rip each title to avi using FreeDVDripper, and then converted them back to DVD using AVI2DVD, changing PAL to NTSC. The problem is, I am using the ImgBurn to burn the ISO file and that only lets me fit one movie on a DVD disk. What can I use to fit more than one?
Can't you load several episodes in avi2dvd and make one dvd from them? If not then use something else like convertxtodvd or if you prefer free tools try favc.
I wanted to use free tools since I don't do much with video files and I really don't know much about the whole process. Even with free tools I often have no idea what all the options and terms mean (and I do read all the instructions I can find).
The quality is not that important, since these are old movies (late 70s) and the original quality is not that great to begin with. I needed ease of use and I really couldn't find an easy way to convert PAL to NTSC.
How else could I go about converting one PAL dvd disk (with 4 titles on it) into one NTSC dvd disk. Using free tools? Easy tools!
Fitting more onto a DVD
By Woolen Llama in forum Authoring (DVD)Replies: 14Last Post: 23rd Sep 2010, 06:31 -
fitting mpg to DVD
By geos in forum Authoring (DVD)Replies: 5Last Post: 21st Dec 2009, 17:54 -
Fitting more in the dvd
By btkuehn in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 16:53 -
fitting four hours on 4.7 GB DVD
By cthiesen in forum Newbie / General discussionsReplies: 34Last Post: 13th Apr 2008, 16:36 -
fitting more than 1 film on a dvd - help!
By welshgal in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 12:16
