Hello,
I am getting an error with VirtualDubMod, Avisynth open failure: the return value was not a video clip. I am trying to De-Interlaced using TomsMoComp. Are these commands right that I am going to post below? I am going to encode to DivX.
LoadPlugin("C:\Program Files\DGIndex\DGDecode.dll")
LoadPlugin("C:\Avisynth_2.5\TomsMoComp.dll")
MPEG2Source("I:\The_Godfather1\DVD2AVI.D2V")
"TomsMoComp (0,5,0)"
Remove the quotes and space from the "TomsMoComp (0,5,0)" line
try it like this
TomsMoComp(0,5,0)Donadagohvi (Cherokee for "Until we meet again") -
Thank you but now I am getting Avisynth open failure: script error syntax error (I:\The_Godfather1\movie.avs) line1, column1.Originally Posted by freebird73717
MPEG2Source("I:\The_Godfather1\DVD2AVI.d2V")
TomsMoComp(0,5,0) -
It loaded. Honestly never done these commands before but it worked!
So you got it working? Thats good. Avisynth is a very powerful program and can be very useful, it just has a high learning curve. Once you learn it though you can accomplish pretty much whatever you want to video related.
Cool. Real cool. So if my movie if progressive, how can I use Avisynth commands for progressive? I am using DivX Pro 6.8 along with VirtualDubMod.Originally Posted by freebird73717
I'm not sure I understand the question. However, most avisynth filters actually work best on progressive source because it is easier to work with. It is only when the source is interlaced that it becomes more complicated and you find you have to seperate fields or deinterlace.Originally Posted by php111
What are you actually trying to do with avisynth ? If it is only to load the video for encoding with Virtualdub then you don't need to do anything else to your script.Read my blog here.
Sticky: MVP scripts!
By cwb in forum Media Center PC / MediaCentersReplies: 0Last Post: 15th Sep 2011, 10:11 -
Is there a way to see actions done by scripts?
By Marc01FR in forum ffmpegX general discussionReplies: 1Last Post: 21st Jan 2011, 14:27 -
About using AviSynth scripts with MeGUI 0.3.5.0.
By Nagashi in forum DVD RippingReplies: 56Last Post: 15th Jul 2010, 10:15 -
What are your favorite nautilus scripts?
By freebird73717 in forum LinuxReplies: 2Last Post: 16th Feb 2008, 17:28 -
Scripts for Conversion
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 06:50
