Hi ,
Is it possible to just extract the audio from a xvid movie, and change the VBR to CBR , then put back onto the movie ?
I just tried to change using TMPGEnc but the encode time is 5 hours...wondering if other qucker solutions
last time i did something like this, i had a video in 2 halves that i wanted to join, but virtualdub complained about the VBR and wouldnt let me... so i put the AVI directly into Goldwave, which demuxed the audio straight out of the AVI. i did the required audio joining, then i outputted the audio as an mp3 (lame required)....had to demux the avis by putting them one at a time into virtualdubmod, disabling the audio stream, then re-saving them...then i was able to re-compile both videos and the new audio in VDubMod easily.
never absorb anything bigger than your own head -
Hi radixmind, I got as far as extracting the audio with Goldwave and changed the audio to cbr Mpeg *mp3*,Originally Posted by Radixmind
however when i load the avi movie into virtualdubmod i cant see were i load up my new audio file ?
must be missing something cant work it out...anymore help ?
regards
mike -
You can run it through Avi_Gain_Regular.bat to create CBR audio.
https://forum.videohelp.com/topic314909.html -
VDubMod/streams/stream list/addOriginally Posted by usermm
Extracting Just The Musical Audio
By niteghost in forum Authoring (VCD/SVCD)Replies: 9Last Post: 6th Jan 2011, 06:09 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 17:22 -
Extracting Music from Audio CD
By prayami in forum AudioReplies: 4Last Post: 4th Aug 2008, 18:59 -
extracting audio from submenu
By juetenglord in forum Authoring (DVD)Replies: 3Last Post: 18th Feb 2008, 08:29 -
Trimming then extracting audio
By chrishallowell in forum EditingReplies: 3Last Post: 2nd Nov 2007, 01:29
