  1. Is there any difference in quality between players? I used to use RealPlayer, but was told the quality was lower than if I used WinAmp. I really just wanna clarify if there's any difference in quality amongst all the players, and if so, which has the highest quality.
  2. Play the same file using both players and judge for yourself. Yours is the only opinion that really matters in such things.
    -drjtech
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Another note just be sure it supports purchased music files if you have any. Or subscription files also. You may not be able to play those with some of the non mainstream players.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Anything with DRM will most likely only play in a specific player, anyway.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    well windows media player does work with wma encrpyted files.
    Oct 2007
    real player wraps itself round your registry and likes to phone home all the time.
    use real alternative or gom player imo
